06-12-2019, 06:51 PM | #15 |
Drives: A10 LT4 Join Date: Aug 2016
I'm sure there are other members in the Austin area that would be glad to hook up with you amigo...easiest thing to do would be to let another ZL1 owner driver yours & then jump behind the wheel of his.
There is nothing sluggish about it & getting the tires to bite under wot should really be the norm...especially when they are not warmed up. Good luck, I'm sure you will get it figured out...do you have the M6 or A10?? |
06-12-2019, 06:52 PM | #16 |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
I put the ADM reservoir on mine and it fixed the problem. Getting the air out of the stock hose is very frustrating. After the ADM was installed I was a good bit quicker in a straight line at VIR. Between this mod and taking off the Rotofab it felt like a different car and I was very pleased.
06-12-2019, 07:14 PM | #17 |
I have noticed that my 2017 is slow feeling too when cruising around town but when I stomp on it, it comes alive and takes off. I came from a 2016 SS 6 speed and it seems like my ZL1 runs like the SS did when driving it normally. I think the weather has a lot to do with how the ZL1 runs because mine ran different in cooler months,have had it since early March, than now in June!
06-12-2019, 07:22 PM | #18 |
Something isn't right. The car is legitimately fast by any standard. Mine left me feeling giddy/amazed every time I took the car out and got on it. Even at 120+ the car pulls hard.
I have a different car with about the same amount of power as the SS (similar 0-60 times also) and there is no comparison to the ZL1. |
06-12-2019, 07:28 PM | #19 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
With 200 more up and ft lbs of torque it should fry the tires easily. Have you put the gas to the floor to see what it does?
06-12-2019, 07:29 PM | #20 |
Drives: 2018 ZL1 Join Date: Mar 2019
not being a total tool bag but I feel the op here. when I bough my Zl1, and C7 Z06 I felt the exact same thing! I live in Houston (hot af) and thought wow maybe it's pulling timing. After having a few other ppl who are sorta use to fast cars drive it and give their .02 I discovered that it's not the car but me. every car I had prior was cammed, and decently modded. I just did the same with my C7 Z, and now at 714/722 I'm satisfied with it for a dd. My ZL1 has no motor as we speak bc it's under the knife lol.
3 weeks ago I bought a new (2018) denali 3500 single wheel shortbed diesel bc I needed a new truck and chose this one (I'm more of a Ford truck guy) bc of all the hoopla of how fast the new L5P diesel is stock. tbh I can't wait to get it deleted and tuned (8k) bc it is not truck fast to me at all. op do headers, X pipe, E85 (if available), and an upper pulley. If that does not scare the shit out of you and wake it up big time shoot for a cam, meth, ice tank and porting work. The sky is the limit on these cars but stock wise they are not crazy fast (unless you are coming out lf a 3 valve mustang or similar). I would go that route and see how you like it. |
06-12-2019, 08:41 PM | #21 |
Drives: ZL1 Join Date: Jul 2017
I live in Austin. I'll test it out for ya.
06-12-2019, 08:58 PM | #22 |
Drives: Chevy Camaro Join Date: Apr 2019
Ok so maybe it's just me.. I just ran several 0-60 runs. Couldn't get the tires to stick at all. Idk how to do a 0-60 without spinning badly unless I ease into the throttle. Which hurts the time. The best I got was 4.0 flat. With an average of about 4.3. Not great but imagine that's fast considering the tire spin. Idk... The car just doesn't have that get up I imagined it would have.
06-12-2019, 08:59 PM | #23 | |
06-12-2019, 09:00 PM | #24 | |
I have the A10. |
06-12-2019, 09:02 PM | #25 |
The tires do spin out pretty good about a second after I floor it. I'm starting to think it's just me. Either my lack of driving skill or unrealistic expectations. Or both
06-12-2019, 09:04 PM | #26 |
06-12-2019, 09:06 PM | #27 |
Drives: 19' ZL1 1LE Join Date: Nov 2015
My 2019 M6 ZLE also felt slow. I have owned many cars that had 800-1000 horsepower at the wheels and I learned something along the way. With very sticky tires a car with good HP feels slower than it does with tires that can't handle the torque. I timed my car with Dragy and it is indeed much faster than it felt. It is exactly where it should be on the times it ran.
06-12-2019, 09:08 PM | #28 | |
Tags |
camaro zl1 2019 |
