Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 06-03-2019, 08:50 PM   #1
Charlescj
Drives: 1997 Camaro 2011 Camaro RS
2011 RS Camaro Won’t Start
I have a 2011 RS Camaro with 55,0000 miles on it. I can’t get it to turn over, it makes no noise whatsoever when u turn the ignition to start, lights, radio, windows work.
I’ve eliminated the following:
Bad Battery
Tried spare key
Starter is good
Fuse n relay good
Battery cables good.
Any Suggestions?
Thanks!!
Charlescj is offline   Reply With Quote
Old 06-03-2019, 09:00 PM   #2
Wierd Harold
Drives: 2017 2lt rs
Check the clutch safety switch if manual trans.or neutral safety switch if automatic.
Wierd Harold is offline   Reply With Quote
Old 06-04-2019, 11:10 AM   #3
bdavies11
Bad Battery
Tried spare key
Starter is good
Fuse n relay good
Any Suggestions?
Thanks!!
Have you had issues with slow cranks? Worse when the motor is hot? I hadd these issues recently and turned out to be a bad ground. Have your dealership check that out.
bdavies11 is offline   Reply With Quote
Old 06-04-2019, 12:20 PM   #4
VinnAY
Drives: 18 1SS/1LE
Moderator needs to clean out this sub forum
