Old 05-21-2019, 05:38 AM   #1
Max Droptop
Max Droptop's Avatar
Drives: 2019 Camaro SS Convertible
Fooling the Computer
So in my 2013 Camaro Convertible I was able to disconnect a plug in the trunk and eliminate the cover hiding our tops. That way my top went up and down without having that piece installed. I left it not installed.
So that was the older system, is there any trick to being able to disable the new system so it does not matter if the small divider is installed or not?
I will keep it installed but would prefer it not being functional just in case I hit a bump and it comes loose, not allowing top operation.
Thanks for any insight.
1969 Z-28 302CI/4-Speed
1989 Camaro 350CI/ AT
2013 RS Convertible V6/AT
2016 SS 376CI/AT
Max Droptop is offline   Reply With Quote
Old 05-21-2019, 05:46 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
There's a magnet in the the upper right (rear top passenger side) corner of the divider, and a sensor on the car. Cut the last few inches from corner off the divider and snap it into place. Voila!
See picture here:
https://www.camaro6.com/forums/showp...57&postcount=7
Old 05-22-2019, 04:18 AM   #3
Max Droptop
Perfect!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks!!!!!!!!!!!!!!!!!!
2016 SS 376CI/AT
Old 05-22-2019, 03:11 PM   #4
sklippi2018
sklippi2018's Avatar
Drives: 2023 Camaro SS 1LE
Brilliant!
sklippi2018 is offline   Reply With Quote
