12-18-2017, 08:52 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Jun 2017
Ferrada 20x10.5 / 20x11.5 fitment
Hey guys,
I've only seen one individual run this setup on their 6th gen Camaro. 20x10.5 +28 20x11.5 +30 Yes, it is aggressive. It does poke some in the rear but it isn't as bad as I expected it would be based on the images I have seen. My only concern comes with lowering springs along with this aggressive fitment. In my experience in the past, when the car is lowered, the wheels will naturally come inward even when correctly aligned. Does anyone have any experience here? What's the most aggressive fitment you have seen so far? Thanks. |
12-18-2017, 09:04 PM | #2 |
Drives: 2017 1SS Join Date: Mar 2016
This is the set up I was thinking of going with for awhile but concerned about the poke. I can live with 2-3mm. Shouldn't set up be 20x10.5 +15 -16 out front? Id love to see pics, I see Mustangs running this aggressive stance
12-18-2017, 09:20 PM | #3 |
Drives: ZL1 1LE Join Date: Oct 2016
You won't get a 10.5 +28 to fit on the front unless you run a big spacer.
12-18-2017, 09:58 PM | #4 |
Sean, it's been done. Like I said, there has been one 2016 Camaro SS that has ran these specs already successfully. It pokes in the rear some but front looks good. He's been running it for a while now so no problems, I suppose.
12-19-2017, 12:42 PM | #5 | |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
You might be thinking 19s. I run a 19X10.5 thats +15... and ITS close enough you cant even get a finger tip in there. You are talking going another half inch inward. You can try running positive camber to see if it works /s |
12-19-2017, 01:27 PM | #6 |
Drives: camaro Join Date: Nov 2011
Yup I recall doing a set of FS01 wheels for Sean also a member here on the forum that ran a 19x10.5 front 14et and it was also one of the main specs for our current inventory for M716 ( ZL1/1Le ) version.
12-19-2017, 07:45 PM | #7 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2017
Yes, I would like to see a picture of those. That is the setup I want with the FR1 in silver. I am sure Paul at PK will know. There is a 5th gen with them and it looks good, but have not seen a 6th.
12-19-2017, 09:06 PM | #8 |
Ahhhh yes. I didn't even think about 19 vs. 20.
Disregard.
12-19-2017, 10:13 PM | #9 |
Let's see those pics of the 6 Gen.
12-19-2017, 10:25 PM | #10 |
Flush up front and some poke in the rear is exactly what I want, that classic muscle car look, aggressive, can't wait to see a pic of it
12-19-2017, 11:22 PM | #11 |
Here are 3 images of the Camaro I am referring to. I have confirmed the wheel sizes with the owner. No rubbing or issues but he’s at stock height.
12-20-2017, 07:53 AM | #12 |
Wow, perfect fitment and concave IMO. Thanks for the pics
12-20-2017, 02:37 PM | #13 |
Drives: 2017 Chevrolet SS 1LE Join Date: Oct 2016
So the setup can work lowered sir, question is how low are you going?
12-20-2017, 06:12 PM | #14 |
