Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 06-17-2019, 03:45 PM   #99
Originally Posted by Midblues View Post
Actually no you dont have to be deliberate to activate it just get on it and go above the set rpm and its on. Sorry should be an option to disable it. Its annoying when you dont want to use it and just have some spirited driving. Thanks anyhow I just figured I would ask.
So how do you know it's activated other than reading this thread?
How does it in any way affect the way your spirited driving?
Since you are shifting by lifting off the gas pedal it's completely deactivated which is the old school way of doing it so I can't even remotely think of how this is an issue.
Maybe check out the section on skip-shift.
Old 06-17-2019, 04:04 PM   #100
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Yeah, I'm trying to figure out what he's doing & why NLS is a problem for him. It activates when you've got the gas floored and shift above 5k (4400 for I4/V6). The No Lift Shift pretty much just keeps the car happy when you're powershifting. Not really sure what his issue with that is. And if he isn't trying to powershift ... its not doing anything.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 06-17-2019, 04:28 PM   #101
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Perhaps it takes a fraction of a second for the NLS feature to realize that a driver is running the engine above the threshold for NLS to work but is making a lift-foot upshift anyway. That could hold the revs up momentarily rather than letting them drop back immediately. I'd imagine that there could be some variation in how much/how long it takes to drop out of NLS.
Norm
Old 06-17-2019, 07:44 PM   #102
Midblues
Drives: Chevy Camaro 2019 Turbo 4 LT 6sp
I think Norm Peterson got it. It just hangs enough for me to hear it and feel it. This is my first 4 cylinder turbo also used to the v8 rpm seems to drop quicker on those. But thanks for everyones input I will let her break in a bit for awhile and see what happens.
Midblues is offline   Reply With Quote
Old 06-17-2019, 07:52 PM   #103
Okay, I don't believe I4 turbo was mentioned before and you may be right about how rpm drops. Now you have me curious to drive one.
I'm kind of thinking NLS might be even nicer when the RPM doesn't drop as fast. I will add once you get used to it when going WOT it comes totally natural.
Old 06-17-2019, 08:51 PM   #104
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I thought maybe he was hitting the clutch pedal a little early causing the rpm to cut.
'18 1SS 1LE Black, PDR
Old 06-18-2019, 12:13 AM   #105
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
turbos often have bad rev hang. That's what it is, not NLS. Rev hang.
Old 06-18-2019, 06:51 AM   #106
VinnAY
Drives: 18 1SS/1LE
Originally Posted by DaveC113 View Post
IME most all modern engines do this at times and to a degree. It's called rev hang afaik... it's really bad on some cars.
I'm pretty sure it has nothing to do with the NLS feature, it's for emissions.
That's right. The rev-hang has more to do with emissions control of not allowing the throttle to snap closed suddenly. Has nothing to do with NLS
Old 06-18-2019, 06:54 AM   #107
Norm Peterson
If it was, I didn't see it either (and "Drives: Chevy Camaro" under the avatar pic isn't enough information either).
As mentioned, turbocharged cars do have some reputation for rev hang. But it's hard to say under what conditions it'll be worse and when it won't be as bad. On our new WRX, rev hang is horrible on the 1-2 if you're hurrying it at all. But almost completely absent if you aren't, and unnoticeable between other gears under . . . let's call it "moderate enthusiasm" using maybe 80% of redline and shifting carefully but reasonably quickly.
On re-reading Midblue's original thoughts it also occurs to me that if NLS was calibrated more for the straight line crowd it's not going to suit the corner-carvers - or those who drive less "brutally" - nearly as well.
When the revs are intentionally held higher than the next gear requires, you gain a brief acceleration spike as flywheel inertia converts to additional driveline torque as it decelerates to the rpm that matches road speed. This spike is also what helps you chirp the tires on a harsh upshift. But it isn't particularly useful at autocross or out on the big tracks where smoothness is the preferred quality and where reducing shift time to some absolute minimum normally isn't all that important.
Norm
Old 06-18-2019, 10:26 AM   #108
Boost Creep
Drives: '18 1SS 1LE
Norm
Well said.
Old 07-11-2019, 07:01 PM   #109
Cmsirois18
Cmsirois18's Avatar
Drives: ‘19 SS 1LE
What is the target RPM for ‘19 SS 1LE?
Cmsirois18 is offline   Reply With Quote
Old 07-11-2019, 07:51 PM   #110
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Almost certainly 5000rpm - same as the '17-'18.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 07-26-2019, 07:05 PM   #111
Midblues
Thanks everyone for the replies. Question for 2.0 turbo drivers, now that I have changed oil I am getting on it a little more and tried this NLS so my question is when I do it very smooth sifts no power loss but turbo seems to make a fart noise like an exhaust brake on a truck,is this normal for 2.0 drivers? Sorry so many questions new to NLS and turbos learning as I go.
Old 07-27-2019, 04:39 AM   #112
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Just guessing here but doesn't a turbo use a blow off valve so that it doesn't over boost when the clutch is in?
BSR-1 is offline   Reply With Quote
