09-22-2017, 08:26 PM | #1 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
Removing heat extractors
As the title says.. I am thinking about ordering new ones and while I haven't looked closely yet - was wondering how one removes/installs them?
Appears in the images that there are two tabs on them?
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
09-27-2017, 07:43 PM | #2 |
Drives: 2017 Summit White 2SS Join Date: Jan 2017
would like to know this as well as i plan to go over them with some matte clear
Follow me on IG: @lip_stick.ss
09-28-2017, 05:28 AM | #3 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Iirc, remove the hoodliner, then there's one or 2 10mm head nuts you remove. Then there's a bunch of little clips all the way around. I think i started in the front. Release the 2 farthest forward (closest to the rain tray) and push outward. It's a pita to push out because of the 3m that holds them on as well.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
09-28-2017, 03:20 PM | #4 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
if you end up selling your current set, please PM me.
09-28-2017, 08:05 PM | #5 | |
Drives: '16 2SS Join Date: Feb 2017
Did mine last weekend, took like 10 mins..... just don’t drop the 10mm nuts. Not sure where one of mine ended up |
09-29-2017, 11:26 AM | #6 |
Bottom of that aluminum shear plate haha. I've done that with another bolt. It sucks!
"Spitfire" 427ci
09-29-2017, 11:28 AM | #7 |
If I could do it again, id try to poor a little goo be gone in the crack between the heat extractor and hood. Just to make it a little easier to seperate the 3m
"Spitfire" 427ci
09-29-2017, 07:22 PM | #8 |
Thanks.. Il have a look at what ide be up against.
04-16-2019, 10:34 PM | #9 |
Datinurmomlikeitsmyjob
Drives: 2018 SS 1LE & 24’ ZL1 Join Date: Jun 2018
Yep did heat extractors today and while popping out those plastic thumb tacks/rivets one of them buggers popped out far and shot right down through the bottom of the engine bay.. I have no idea where it went down below to the tray at the bottom. Wish I could get to it
04-16-2019, 10:57 PM | #10 |
Currently working on my hood heat extractor vents...
Hood heat extractors/vents are my current project im working to complete by tomorrow evening. I read ,watched, and asked dealership body shop guys about removing these. Most consensus was that they were a pain in the ass to remove from the hood. Due to the adhesive of 3m seal around them stuck to the hood cut outs from factory.
However for me that was not the issue, once I got those large finger tab clips free by depressing them the extractors were ready to be pulled out. I used a acrylic automatic tool wedge edging around it to break it loose easily without damager to my 1LE blk satin factory hood wrap. that said for me the difficult was breaking loos the 2 parts that were together for each extractor once I removed it from the hood. the extractor has 2 pieces (the top piece that is visible that you see looking at the hood. And the bottom piece that is attached which you visibly see when the hood is up: those tabs holding those two pieces together were a b*tch for me to get pulled/released apart. have about 2 more coats to put on the bottom pieces of the extractors then I Should have everything re-installed later tomorrow> I'll post the completed/end result pics next |
04-17-2019, 08:10 PM | #11 |
Heat extractor insert painted completed!
I was able to finish adding red accents to the hood heat extractor/vents...
came out just as some had done on here. |
04-17-2019, 08:23 PM | #12 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
I easily removed the bottom trays for painting without removing the top half.
06-10-2019, 08:56 AM | #13 |
Drives: 2011 Camaro RS/SS Join Date: Oct 2016
Looks Awesome!
06-24-2019, 03:57 PM | #14 | |
Long hauler
