Old 06-05-2018, 12:04 AM   #15
RomanB
RomanB's Avatar
Drives: 2LT RS Yellow Convertible
It's mounted between the rear seats and aimed so that it looks just above the spoiler. You won't be able to read license plates (Michigan doesn't have front plates anyway), but if somebody screws with your car while it's parked, or if you are hit from behind by someone approaching too fast or not braking, you'll pick it up.
Hi Martin, the mount for the back camera looks pretty need. Where did you get it from? Thx in advance!
Gold Rush
RomanB is offline   Reply With Quote
Old 06-05-2018, 12:43 AM   #16
Martinjlm
Retired from GM
Martinjlm's Avatar
How's the picture through the back window with the top up?
I’ll have to pull a still tomorrow morning.
I had the whole set installed at a car audio installer. They made the little bracket.
Old 06-05-2018, 04:05 PM   #17
Martinjlm
Retired from GM
Martinjlm's Avatar
Had to post this. This is one of the reasons I have a dashcam. Stupid people. No sound on the video. These two future rocket surgeons decided to try to time my car as they crossed the street. Keep in mind there is NOBODY behind me. I wound up slowing down from 40 to 17 mph and blowing the horn before they stopped. Then they had the nerve to get mad.
https://youtu.be/CcUP-uF1LDU
Also including a still from the rear camera for GroundhogSS
Old 06-05-2018, 06:03 PM   #18
Whatwarranty
Drives: 2016 camaro ss
https://www.amazon.com/gp/aw/d/B071L...o_pop_mb_pd_t2
I run this one it’s great
Whatwarranty is offline   Reply With Quote
Old 07-18-2018, 05:38 PM   #19
jeffm5690
jeffm5690's Avatar
Drives: 2023 2SS 1LE
Would anyone be willing to share their wire routing? I am expecting a delivery of a blackvue this weekend and was curious on how you ran the wires for front and rear and where you hid, and tapped for power.
Cheers!
2018 2LT/RS Hyper Blue
Cosmetics - Bow tie
Front/Rear Dashcam (Blackvue)
2010 2LT/RS IBM
K&N Aircharger
MRT V2.0 Exhaust
Trifecta Tune
Soon to be added:
Elite Catch Can
Iceolater
Vmaxx Ported TB
Cosmetics - Rally Flags, Door Sillplates
Electronics - Escort Hardwired
jeffm5690 is offline   Reply With Quote
Old 07-18-2018, 09:21 PM   #20
Cheers!
I have a Blackvue DR-750S 2CH and installed it myself. Since I didn't want to go to the engine bay fuse box through the firewall or have any wiring visible when opening the passenger door, I decided to use the trunk. Routed the rear cam hookup cable under the headliner on the driver side, all the way to the top center of the rear windshield, while the power cable is routed on the passenger side, first under the headliner, then behind the C pillar trim piece, down into the battery compartment via a suitable opening at the bottom of the pillar (I used a rigid plastic stick and attached the cable with painter's tape to guide it in), finally down into the trunk where the fuse box is. Having no idea whether this would actually be feasible, I had used a wireless endoscope camera to discover the area first.
Since I didn't want too much excess wire in the trunk, I started routing the power cable from there, but if I did it again, I would try to start from the front cam, because the way I did it there is about a foot and a half of excess that I had to tuck under the headliner close to the front cam.
The PowerMagic Pro box is attached to the frame under the trunk liner using double-sided sticky tape, and I also sheathed all wiring in the trunk area with a braided sleeve + adhesive fabric wire tape for improved looks and just in case water ever leaks in.
Here are two pictures of my wiring into the trunk fuse box:
https://www.camaro6.com/forums/showp...3&postcount=35. The bolt I used for grounding is a bit too large for the wire lug on the ground wire that comes with the camera, so I broadened the lug opening it a bit before bolting it down.
I'm not saying these two fuses I used for constant and switched 12V are the definitive or recommended choices, but it has worked for me since April without any errors.
Overall, this was a relatively easy install, and without trying to toot my own horn, it looks near OEM, nothing is exposed anywhere, the braided wiring is a perfect match, the only telltale sign is the fuse taps when one opens the fuse box, of course. I can take more pictures and post them tomorrow if you are uncertain about any of this.
Hope you get your package soon, have fun installing the dash cam
Old 07-19-2018, 02:29 AM   #21
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
There's A LOT of review sites out there for these things so I won't argue with anyone on specific brands.
Main features you want are:
Battery Backup Power
Memory Card Slot
Impact Sensor
Front and Rear Cameras
Sound Recording
Bluetooth or WiFi connectivity to phone so you can view videos easily for instance if you think you were hit.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 07-20-2018, 08:31 AM   #22
wjmeyer
wjmeyer's Avatar
Drives: 2016 Camaro RS, 2LT
I like my Viofo A119, it does 1440 resolution, under $100.
wjmeyer is offline   Reply With Quote
Old 07-20-2018, 04:38 PM   #23
jeffm5690
jeffm5690's Avatar
Thank you. Was thinking of the same routing. Interesting... they shipped it with the OBD connector which in theory eliminates the wiring to the fuse box, but I hate to have something plugged into the obd all the time. In my 5th gen I had my aero force gauges but haven’t decided to add them yet and hate to have to reroute.....
Not sure.
Cosmetics - Bow tie
2010 2LT/RS IBM
K&N Aircharger
MRT V2.0 Exhaust
Trifecta Tune
Soon to be added:
Elite Catch Can
Iceolater
Vmaxx Ported TB
Old 07-20-2018, 07:04 PM   #24
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1969 Cessna Skylane
Cheers!
I haven't installed a dash cam, but I have ran wires inside from the engine compartment. From the fuse box I installed a fuse tap and whittled out a little notch in the fuse box and cover to run the wire through with my dremel. From there I used some split-loom tubing to run the wire around the passenger side of the engine compartment to the lower rubber stopped hole near the passenger side door hinge. From there it's pretty simple to run it behind the threshold trim piece and up through the passenger side window pedestal.
Another option is to tap power off the dome light.
https://www.camaro6.com/forums/showthread.php?t=440254
dfwcowboy is offline   Reply With Quote
Old 07-24-2018, 02:32 PM   #25
jeffm5690
jeffm5690's Avatar
So you used F17 Camera as you always on source?
Did you run the wire from the front under the headliner to the back or down the front pillar?
Cosmetics - Bow tie
2010 2LT/RS IBM
K&N Aircharger
MRT V2.0 Exhaust
Trifecta Tune
Soon to be added:
Elite Catch Can
Iceolater
Vmaxx Ported TB
Old 07-24-2018, 04:10 PM   #26
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Rexing is the way I went and I really love the quality of the cam, the sound is great and with the Timacam app on my iPhone it allows me to control it and do what I need for it to do.
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 07-25-2018, 10:07 PM   #27
Asmodeus
Drives: Camaro SS 1LE
Waylens Dashcam
i went with the waylens horizon dashcam because i couldnt get the pdr and while its not perfect i get videos like this;
hope to fix the shaky cam for the next trackday.
Asmodeus is offline   Reply With Quote
Old 07-31-2018, 10:07 PM   #28
Sorry for the late reply, for some reason I didn't see your response earlier
Yes, I used F17 for the battery and F23 for the accessory hookup, same rating for the additional fuses as the originals. The front to back camera connection wire runs under the headliner all the way on the driver side, I didn't use the A pillar. The power cable also runs under the headliner, but on the passenger side, then down the C pillar into the trunk. No wiring is visible except for the last two inches or so in front and the last half inch for the rear cam.
