dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-10-2022, 02:10 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Serviceable or not an issue?
While removing my driveshaft today, I noticed the backend of my M6 transmission had a severed bushing or gasket. There doesn’t seem to be anything leaking at all.
Is this serviceable or is it even an issue?
Look closely and you can see the severed section.
Car: 2011 2SS M6
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 07-10-2022, 09:31 PM   #2
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
That’s on the output shaft of the transmission?
gtstorey is offline   Reply With Quote
Old 07-10-2022, 11:41 PM   #3
dma05
dma05's Avatar
Yes
Allen
2011 Camaro 2SS/RS
Old 07-11-2022, 07:04 AM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Yes, that seal is replaceable. In your case, with the shaft out, you might want to go ahead and replace it. Normally, if it did not leak, I would leave it.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 07-11-2022, 08:24 AM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Car: 2011 2SS M6
How many miles on the car? Was the driveshaft ever removed before?
camguynj is online now   Reply With Quote
Old 07-11-2022, 10:49 AM   #6
dma05
dma05's Avatar
The car has 150,000 miles on it. Yes, I have taken the driveshaft out several times for other installs. It’s a 1 piece shaft.
How difficult is it to change this part out? Any part numbers?
Allen
2011 Camaro 2SS/RS
Old 07-11-2022, 11:25 AM   #7
gtstorey
https://www.gmpartsonline.net/oem-pa...Y4LWdhcw%3D%3D
Old 07-11-2022, 11:58 AM   #8
CamaroCracka
It's not that bad, but I've never done it in the car. Mine was out for a build when I changed it.
Old 07-11-2022, 12:25 PM   #9
dma05
dma05's Avatar
Thanks for the link!
I figure I might as well change the seal while I’m there. Anything else that should be changed in that area?
Allen
2011 Camaro 2SS/RS
Old 07-11-2022, 02:17 PM   #10
dma05
dma05's Avatar
Do I have to drain the transmission fluid first for this job? Or is the fluid low enough when the car isn’t on that it won’t leak when changing the seal?
Allen
2011 Camaro 2SS/RS
Old 07-12-2022, 05:34 AM   #11
CamaroCracka
It would probably be wise to take a quart out. You might know this already, but if you hold a vac hose on the open fill hole while you take the drain plug out, fluid won't come out until you take the vac hose off the fill. It will allow you to control how much oil you drop and you won't make a mess putting the plug back in with oil still in the trans. Works for when you overfill your oil too.
Old 07-12-2022, 08:12 PM   #12
oldman14ss
Drives: 2014 1ss camaro
that nut takes a special socket to get off ad torque value on install is 100 lbft high dollar socket i paid 75 bucks for it at freedom racing. donated it to the tech who built my transmission . great guy. very,very smart man
oldman14ss is offline   Reply With Quote
Old 07-13-2022, 12:44 AM   #13
dma05
dma05's Avatar
I know many say to torque to 100 ft lbs, but in the ProDemand service site, it shows differently, unless im reading it wrong. It also looks like you need to replace with a new washer and nut.
1. Using J 44765 install the new transmission case extension seal (1).
2. Install the drive flange to the transmission output shaft.
3. Install a NEW drive flange thrust washer.
4. Install the J 45012 to the drive flange.
5. While holding J 45012 , install a NEW drive flange nut using J 29873.
6. Tighten the drive flange nut to 57 N.m (42 lb ft).
Allen
2011 Camaro 2SS/RS
Old 07-13-2022, 01:49 AM   #14
dma05
dma05's Avatar
So now I’m really confused. The instructions on my last post are for “on the vehicle” but I found a section for “off the vehicle” and it says to torque the Propshaft Nut to 100 ft lbs.
They are the same part. Why different torque specs? WHYYYYYYYYYY!!!
Allen
2011 Camaro 2SS/RS
