07-03-2022, 07:57 AM | #1 |
Drives: 2018 SS Join Date: Jul 2020
Radar detector installation
Hey everyone
I want to get a radar detector Haven’t had one since the 90s and would rather not advertise too loudly when mounting however, how to balance performance and hidden mounting? I have a convertible so it’s likely windshield or visor I think Any tips or ideas? Looking at a Valentine V1R2. Want something decent but not to break the bank if anyone has tips on the unit as well. Thanks guys! |
07-03-2022, 08:48 AM | #2 |
Drives: 2022 Camaro ZL1 Join Date: Jan 2022
Radar Detector
I bought a Radenso DS1 and really appreciate the range and straightforward menu. Its a compact unit and was easy to set up, and I just used the suction cup mount provided which has worked without a problem.
07-03-2022, 09:08 AM | #3 |
Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
I have a Uniden R3. I have it mounted using a bracket I bought on eBay mounted to the glass with 3M tape right behind my mirror. Can't be seen from the rear but yet will detect behind me still. As for wiring, verts are tricky pulling the trim down to find keyed power. That took me a while but works with no issues.
07-03-2022, 12:58 PM | #4 |
Drives: chevrolet camaro Join Date: Jul 2020
Using a new Valentine 1 here and really like it. For mounting I used the supplied slim suction cup windshield mount up high next to the mirror on the drivers side. Being that the windshield real estate is small this is extremely discrete and easy access to hit the mute button if needed. The mount is stuck partially in the black painted dot matirx of the windshield and regular glass. To ensure this sticks I put a little glob of silicone on each of the suction cups. Easy removal of just the detector leaving the small mount when parking in a high risk area can quickly be done. If and when you want to remove the mount it will come done and a razor blade will easily get the remaining silicone off.
07-03-2022, 01:12 PM | #5 |
It'll absolutely be visible when mounted to the windshield or the mirror in a convertible, if you really want a completely stealth solution, you'll need to break the bank with an integrated detector such as the K40.
My personal setup has a Blackvue dash cam mounted to the windshield using their included, very strong and heat resistant tape, then right behind it is a cheap Uniden DFR9 that does 90%+ of what the R3 can do, but it's half the price and, unlike the R3, has the power socket on the right (passenger) side, which was a dealbreaker for me with the R3. I used a Blendmount mirror bracket for the radar detector, and wired it to the overhead console using Gen5DIY's harness, so there is no "wire intrusion" into the cabin, just the 4-5 inches of wire from the detector to the headliner, even less for the dash cam, looks 99% OEM. (Interestingly, the front edge of the factory headliner has a notch in the middle, seemingly for this very cable routing purpose.) This is the best one can do on the coupe, and it should work just the same way on the vert. Whenever driving through VA, the one state where detectors are illegal, I take the detector off and "clip" the cable to the detector mount, because I'm like that.
07-03-2022, 07:04 PM | #6 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Mine does well with the visor mount. You will want to tap power from behind the rearview mirror for a less obvious installation (only possible on 2018 or older model years I believe). If officers use laser instead of K band or Ka band radar in your area, you are looking at spending a few thousand dollars to install a laser jammer which is illegal in a lot of places. |
07-03-2022, 08:12 PM | #7 |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
This is what I did, Uniden R7... works great with mount.
https://www.camaro6.com/forums/showthread.php?t=597761 |
07-04-2022, 07:35 AM | #8 |
07-04-2022, 07:36 AM | #9 | |
Yes, will have to figure out the power situation |
07-04-2022, 07:39 AM | #10 | |
Late yesterday I ended up getting the valentine. Im sure I’ll be happy too I’ll need easy ability to take the unit off as sometimes I park quick w the top down. Will likely do something similar. Need to figure the wiring out |
07-04-2022, 07:40 AM | #11 | |
I’ll likely be the same. Typically only go through va on way to vacation. Will likely just hide it. |
07-04-2022, 08:36 AM | #12 |
Drives: 2023 Corvette C8 Join Date: May 2022
Check out Vortex on Youtube. His reviews are impeccable. Actually he can be too technical for me. Watching his reviews helped me decide to get an Escort Redline 360C. The R8 is also a beast of a unit.
2023 Corvette C8 70th Anniversary Edition
———Gone But Not Forgotten——— 2022 Camaro ZL1 Convertible (Never Delivered and won’t forget) 2019 Camaro SS Convertible 2019 Corvette Grand Sport Convertible 2013 Corvette Grand Sport 2013 Challenger SRT 392 1995 Camaro Z28 |
07-05-2022, 09:45 PM | #13 |
Drives: 04 Colorado, 22 Camaro SS 1LE Join Date: Jan 2010
Rollin' with Escort 9500ix mounted to front windshield. Excellent tool that has paid for itself ten-fold
2022 6.2L V8 A10 2SS 1LE Shadow Grey Metallic
RotoFab CAI, Borla S-Type 11924CFBA, Sullivan Race Pedals, ACS Rock Chip Guards Sold 2010 6.2L V8 6M SS/RS Cyber Grey Metallic 1LE Track Pack, DiabloSport Jammer CAI, Stage1 CAM, Ported & Polished Heads, HD LS3 Timing Chain, Melling High Volume Oil Pump, LS7 Lifters, BTR Trunnion Upgrade, LS3 Springs & Pushrods, JBA Shorty Silver ceramic Headers, Granatelli high temp blue wires w/ Fire sleeves, Borla S-type CAT back, MGW black Flat short throw shifter, Custom Calibration/tune |
07-05-2022, 10:41 PM | #14 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
