05-27-2022, 08:44 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
Z28 Axles - One thicker than the other?
I just received my Z28 axles and noticed the “right” axle is thicker than the “left”. The “left” axle is also longer than the “right”.
Is this how they are or did I get the wrong parts?
Allen
2011 Camaro 2SS/RS |
05-28-2022, 07:37 AM | #2 |
That is normal
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
05-29-2022, 09:37 AM | #3 |
Yes sir, that be how they are..
06-01-2022, 09:21 PM | #4 |
Where did you get Z28 axles from??
Orange Krush II
06-02-2022, 01:46 AM | #5 |
I got them both from www.gmpartsgiant.com I know that the driver side is now discontinued, so once I saw that, I immediately went looking online to order a set before they are fully out of stock. GM Parts Giant was the only vendor that has them in stock. I had to pay an extra fee of $10 since they are a "rare" part. Looks like they still have some in stock, so if you are looking to go the Z28 axle route, you should order them asap. Part Numbers: Drive (left) side: 23473010 Passenger (right) side: 23473011 thanks
Allen
06-02-2022, 08:56 AM | #6 |
Drives: 02 Camaro B4C Join Date: Nov 2016
I ordered a set from Summit. Still waiting to receive them. Should ship next week.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
06-02-2022, 06:24 PM | #7 | |
GMPartsGiant actually finds it at other dealers/distributors that have the actual part. Just speaking from my experience.
Allen
06-02-2022, 08:48 PM | #8 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Do the Z28 axle fit the stock ss rear-end,?
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
06-02-2022, 09:33 PM | #9 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
DO they fit stock SS Set up? How do these compare to aftermarket performance options?
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
06-03-2022, 12:22 AM | #10 |
I have been told they fit the SS differential just fine. I currently have the Z28 Wheel Hubs on my car with the stock SS axles, so the Z28 axles must fit.
Allen
06-03-2022, 07:34 AM | #11 |
They are about $300/$400 cheaper than some aftermarket sets, Which is a good savings if they are a lot stronger than stock. Out of curiosity what advantage does the Z/28 Hub provide?
06-03-2022, 11:01 AM | #12 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Yes, Z28 axles fit an SS and you can put a z28 diff in an SS with stock axles. Wishing I had not sold mine at this point given the cost of aftermarket axles. I have a set of 1le axles in the vert, but if those go, I'm stuck going to GForce or DSS.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
Thread Tools | |
