03-04-2022, 03:47 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Jan 2011
Need help locating bolts - Rear Upper Control Arm
I all new bolts to replace when doing my suspension upgrade soon, but it looks like the bolts for the Rear Upper Control Arm at bushing is discontinued. I called GM and ACDelco and they said they don’t have anything listed to replace it, but that it is definitely discontinued.
Anyone have any ideas where to look? ARP? Here is the GM part number: 92138935 I have the bolt info: M14 x 2 x 60 I’m guessing I just may need to go to my local bolt store and find it? Thanks for any help or ideas.
Allen
2011 Camaro 2SS/RS |
03-04-2022, 04:17 PM | #2 |
Reuse the existing with loctite. Mine has been apart multiple times with no issues.
If you buy a bolt from bolt supplier it probably should be at least a grade 10.9. I don't remember if that particular bolt has a flanged head, but that will be particularly hard to find and you may need to get washers. |
03-04-2022, 04:34 PM | #3 |
I went to my local bolt store, “King Bolt”, and got the same size bolt but had to get washers. These are 10.9 grade and both bolts were the same cost as 1 GM bolt. Once I get the old ones off, I’ll determine if they need to be replaced or not.
Seems like more and more parts for our 5th Gen’s are being discontinued. Sad.
Allen
03-04-2022, 05:05 PM | #4 |
Drives: G8 Join Date: Mar 2012
Hardware store bolts aren't going to last. Goto McMaster Carr, they have exterior grade hardware
Sent from my Pixel 4 XL using Tapatalk |
03-06-2022, 02:17 PM | #5 | |
I don't know much about bolts, but if the grade 10.9 matches the factory grade, isn't that the same exterior grade? Once again, I don't know much about bolts, so I'm looking to understand the difference. Plus, this is a specialized small bolt store I went to, not a hardware store like Lowes or Home Depot. thanks for the help
Allen
03-06-2022, 03:01 PM | #6 |
Grade is the strength, I would go for the "black ultra corrosion resistant - black" basically what the OEM bolts are coated in. The zinc, or usual home Depot hardware will rot out pretty quick
03-06-2022, 03:35 PM | #7 |
It may get slightly rusty but it won’t “rot out” in California.
03-06-2022, 03:37 PM | #8 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
lol, They are not going to rot out pretty quick. Even if you are in salt, the coating will start to degrade but they won't be junk. The strength, 10.9 is the most important. As gtstorey mentioned, the old ones can certainly be reused along with some Loctite. They are not single use bolts.
03-06-2022, 04:54 PM | #9 |
Thank you everyone for helping me understand. I guess I didn't think about the coating of the bolt. That's why I love this forum, you learn something new all the time.
Allen
03-07-2022, 11:17 AM | #10 |
In stock here?
https://www.gmpartsdirect.com/oem-pa...-bolt-92138935 |
03-07-2022, 01:31 PM | #11 | |
Allen
2011 Camaro 2SS/RS Last edited by dma05; 03-07-2022 at 01:36 PM. Reason: wrong info |
03-07-2022, 01:41 PM | #12 |
Try gmpartswarehouse.com. Their shipping rates are the most reasonable I have found.
03-08-2022, 07:04 AM | #13 |
Keep letting us know your progress my Man.
It can be a frustrating process that tests your patience, and sometimes I just walked away and had a beer. Or 3. Then get back at it. A tip for you I used was to ensure everything was torqued was paint stripes (see 1st image below). This also allows a sense check every year to assure nothing got loose after beating on it |
03-09-2022, 07:20 AM | #14 | |
Drives: 2013 1SS Join Date: Dec 2012
