11-24-2021, 11:55 AM | #1 |
Drives: Chevrolet Camaro ZL1 Join Date: Nov 2021
FS: 2015 ZL1 - 10k miles - 761whp
2015 ZL1 - Manual - Black
Only 10,335 miles, under 1k since engine build I am the second owner. Purchased the car with 6k miles on it. Around 7,500 miles the following mods were installed: ATI Balancer ID1050X Injectors 9.17/2.55 pulleys AFCO dual fan heat exchanger Reservoir Tank Coolant Pump Solid Isolator Texas Speed 2" Headers – Catless to NPP exhaust Roto-Fab CAI Dyno'd at 635whp/654wtq At 9,350 miles I had the engine built with the following: Texas Speed Balanced Rotating Assembly - TSP 6.125" Super H-Beam Connecting Rods with ARP 2000 Bolts - Carrillo Forged Pistons; 4.07" Bore, 3.622" Stroke - Clevite P-series Main Bearing and Rod Bearing Set, CHE trunnion kit - Precision Race Components CNC Ported LSA Heads - TSP Stage 3 Supercharged Camshaft 231/239, .640"/.629", 115 LSA - TSP Chromoly Pushrods - Block bored .05 over, 416 ci - Nick Williams 103mm Electric Throttle Body - Monster LT1-S Triple Disc ZL1 Clutch Kit - Rated for 1150whp/wtq - Kong Ported Blower - Melling Oil Pump - DSX Fuel System - car has never ran on or been tuned for e85 Conservative 93 octane tune - 761whp/766wtq All work done by Brewer Speed and Racing in Columbus, GA. Would make well over 800 if next owner decides to run e85, mods will support. Block was built to handle larger blower/twin turbo but my plans have changed and I don't have much time to drive it. Mickey Thompson ET Street SS 305/45/17 Forgestar Bronze Burst Drag Pack ~300 miles on both Also have stock wheels/tires. Have all receipts for parts and labor ($20k+) in a folder. This ZL1 has never seen the track or Mexico, but would be great for either. Best sounding Gen5 I've heard and runs very strong. Interior is like new, weather-tech mats currently in and original like new ZL1 mats are in the trunk. Exterior is exceptionally clean as well. Garage kept year-round. $55,000 OBO Text 937-901-2476 for more information/pictures. Will be able to get more photos uploaded after the holiday as I will be traveling. Car is located in Midland/Columbus, GA about 1.5 hrs south of Atlanta. |
11-27-2021, 09:35 AM | #2 |
Drives: 2014 ZL1 Join Date: Jun 2009
Badass build!! GLWS!
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Tags |
2015, built, for sale, manual, zl1 |
