07-11-2021, 08:40 PM | #1 |
Drives: 2018 A10 ZL1 Join Date: Oct 2020
Magnuson2650 Pulley combo
A question for who ever went throught the trouble of trying diff type of lower+upper pulley set ups, i am going with a vvt1 *stage1* cam 32% fuel lobe, dsx low side and a jms volt booster and meth for the fueling, i have been wondering if i could go 85mm upper and 9.17 lower with this fueling support? or if anyone tried another setup of pulleys and finds it great I’d appreciate the recommendation i am really lost.
07-11-2021, 09:00 PM | #2 |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
With your fuel mods plus a LPE HPFP and +30’s but no meth I was out of fuel on E50 with a 9.06 lower and 85 upper. Making 18psi. This is a heads/cam 11:1 compression setup though.
07-11-2021, 09:15 PM | #3 |
My tuner said i can go 85mm with 9.17 lower, but i doubted it i think it makes more sense now that its impossible to do so, i am running 13.9 psi now with 85mm and stock lower with meth only, the rest of the mods are yet to come.
07-14-2021, 07:05 AM | #4 |
Dyno Show Queen LOL
2650 ported eforce 8.3 lower 7.62 (3.0) 18/19 psi 112MM TB, 5 inch intake, heads, and cam unlimited fuel on e85.
Here were my results with stock TB, headers, and a stock box with green filter. The maggi flows a little better stock to stock but not when kong ports the stock Eforce should be close enough. A Few results on the 2650 85.51% humidity Temp 75 2017 ZL1 w LTH, stock TB, GM Box w Grn Filter all results on same Mustang Dyno LT4 OEM no mods 551rwhp 567 rwtq All TEST DONE ON STOCK TB, STOCK BOX, HEADERS, and 9.17 LPE lower w stock 2.5 upper LT4 oem SC 641 RWHP 597 RWTQ 9.17 and Stock upper 2650 3.75 pulley 620/613 11 psi 2650 3.50 pulley 637/616 12.5 psi 2650 3.25 pulley 644/633 13.5 psi 2650 3.00 pulley 666/ 636 15 psi 2650 3.00 pulley 701/667 103TB and Prototype Vararam intake
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 07-14-2021 at 07:16 AM. |
07-14-2021, 07:41 AM | #5 | |
Drives: 2019 ZL1 Join Date: Oct 2019
Great numbers on the stock box and TB for just a lower pulley, longtubes and tune. How was the heat soak with the longtubes added but more boost? |
07-14-2021, 07:50 AM | #6 |
Start by asking Maggie.
'20 ZL1 1LE A10,
07-14-2021, 10:26 AM | #7 | |
Drives: 2019 ZL1 Join Date: Mar 2019
I have a 90mm and a 9.06 lower and I’m just on pump, no meth, no low side.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-14-2021, 11:04 AM | #8 |
Dyno Show Queen LOL
I only did the dyno numbers because I went port 2 days later basically drove it over the weekend and right back to the shop for more power. Tuner said it looked fine though.
07-14-2021, 09:53 PM | #9 |
Yeah things been going weird with my boost for some reason i got 12.6 exactly on the stock 90mm and 13.9 exactly on 85mm, with intake/LTH and single nozzle meth, and a volt booster i am making 720/730 on a dynojet, corrected numbers.
Tags |
cam, maggie, pulley, zl1 |
