05-25-2021, 07:37 PM | #1 |
Drives: 2016 Chevrolet Camaro 1SS Join Date: Sep 2019
Cam Ideas for the setup I want
Wondering if anyone can give advice on a build I'm looking into. I want to put edelbrock victor jr cylinder heads with the 2" kooks long tube headers that are built for those heads...high flow cats...x-pipe...muffler delete on my 2016 camaro ss...I already have msd atomic IM with 103mm Nick Williams TB and Rotofab CAI...thoughts on adding a DD cam?
05-26-2021, 12:42 AM | #2 |
Drives: like an old lady Join Date: Jun 2012
i would determine desired cr & ptv then go from there.
05-26-2021, 04:10 PM | #3 |
Drives: Chevy Camaro SS Join Date: Nov 2019
I would try and get a different set of heads. Cam is going to depend on the goals for the car. How much Compression you want to run, how much you want to flycut(if you even want to), and what the car will be used for.
2017 1SS:Hi-Ram, FBO, OTR ram air, Circle D converter. Previous PB: 11.07 @124 1/4 7.1 @100 1/8 1.6 60’ w/2” longtubes, 95mm hi-ram, OTR ramair, flex fuel |
05-26-2021, 10:06 PM | #4 |
Drives: Camaro Join Date: Aug 2020
What is your end goal? If you are staying NA I would recommend that you look around at some different heads and go with 1 7/8 headers.
When it comes to cams there are so many options out there. Everyone is going to have their preference but if you go with a well known brand your going to find they are all pretty close IMO. Check out this video; https://youtu.be/5acvcAyVb7k
2017 Chevy Camaro Hyper Blue 2SS A8 GPI Ported Heads, GPI SS1 CAM, Rotofab CAI, Katech Ported TB, GPI Ported IM, TSP 1.78 Long Tube Headers, Elite Engineering E2 Catch Can, Chevrolet Performance Strut Tower Brace, Factory Reproduction Style 28 Wheels, Michelin PS4S
2017 Chevy Camaro Krypton Green ZL1 Rotofab CAI, Borla Cat-Back, Michelin PS4S |
06-04-2021, 08:03 AM | #5 |
Drives: 2017 Camaro 2SS Join Date: Mar 2017
OP want's a daily driver so the cam probably won't be aggressive. DD cams really don't need to be custom and all that. Probably a stage 1 or stage 2 shelf cam will do the trick.
06-04-2021, 09:42 AM | #6 |
Off the shelf cam with a off the shelf tune(that has a ton of hours of development) that goes along with it would be a smart move
06-04-2021, 11:01 AM | #7 |
You'll get the best info from a Cam company or one of their dealers, BTR, Texas Speed, Pray Performance etc. They'll be able to advise you what you'll need to meet your goals.
06-04-2021, 11:25 AM | #8 |
Cam Motion Titan 2 with stock compression. Titan 3 if you bump compression up and run primarily E85. More cam needs more compression and octane to retain low speed torque and good midrange power.
2016 NFG 1SS A8
06-04-2021, 01:16 PM | #9 | |
BAMF SS
except this one. Don't listen to a single thing in this post..... literally everything in it is wrong. lol.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
06-04-2021, 01:43 PM | #10 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
With the stock pistons, you will not be able to run a cam with any overlap at all. Valve positions and sizes are different than stock, you will smack a piston with any serious camshafts. You can set the piston at TDC and measure vertical valve drop with a dial indicator on the valve to verify.
06-04-2021, 06:50 PM | #11 |
Drives: Chevy Camaro Join Date: May 2021
I'm on a GPI stage 2 cam with a basically similar build (heads, cam, msd, roto, nw103, headers, e) stock converter and i put down 544 thru the a10. no big issues with daily driving. the 2-1 downshift is a bit rough if you arent careful with it but thats all
2019 2SS - 544 wheel N/A thru the A10
06-05-2021, 12:44 AM | #12 | |
06-05-2021, 09:57 PM | #13 |
Thanks for the Info...what kind of heads, headers/exhaust you go with?
06-05-2021, 10:02 PM | #14 |
Thank you for the info..very helpful...what set of heads do you recommend..also I know I can Google it..but I'd rather hear from someone on here...what is flycutting a piston? Will it be my original pistons?
Tags |
2016 camaro 1lt, 6.2l, cam, headers |
