Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-16-2020, 11:59 PM   #1
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Auto trans overheat help
A few weeks ago at a track day my transmission overheated triggering the DIC message. And the gauge in 4 pack looked pegged. I limped back to the pits and shut it down for the final 2 sessions. I don’t think I ran overly hard, I was manually shifting back and forth between 3 & 4 gear around the track. My Camaro is a 2010 SS, cammed and 3200 stall. I have the ADM trans cooler kit. I am currently shopping B&M pan for extra fluid and also adding a dipstick to check. Is there benefit between the Jannetty kit or B&M? Any other tips to add cooling in the event I make it back to the track?
ZWA SS is offline   Reply With Quote
Old 06-17-2020, 08:15 AM   #2
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
Look at the Tru-Cool 45,000 or 34,000 btu cooler. These have worked for others that track.
gtstorey is online now   Reply With Quote
Old 06-17-2020, 01:16 PM   #3
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Yup. I have a 4500 stall and a trucool 40k. Ive yet to see 180 degrees and thats even in stop and go in the 90s temp wise
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
