dave@hennessey
Old 01-28-2019, 10:11 AM   #1
Turbo_J89
Drives: 2015 BVM Camaro 1LE (2SS/RS)
Can you re-install 1LE front splitter?
I'm considering repainting my front bumper and vinyl wrapping my splitter. I have to drill out the rivets and remove the splitter for this. Can you re-mount the 1LE splitter to the bumper? The rivets will be need to be replaced but is the rest of the hardware reuseable?
Turbo_J89 is offline   Reply With Quote
Old 01-28-2019, 01:33 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Only the rivets under the car should need to be replaced. But to answer your question, yes you can reattach the bumper assuming you dont break any of the tabs.
CamaroDreams76 is offline   Reply With Quote
Old 01-28-2019, 01:45 PM   #3
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
I would think you could re-attach the splitter in the correct spot with all new rivets since the holes will already be there. I no when installing the splitter to a new bumper, you need the template to align it corrrectly.
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is offline   Reply With Quote
Old 01-28-2019, 06:33 PM   #4
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
You could also replace the rivets with bolts and nuts if you wanted to
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 02-09-2019, 03:19 PM   #5
Turbo_J89
Splitter Hardware
OEM Aluminum rivets
Old 02-09-2019, 04:52 PM   #6
Turbo_J89
OEM Plastic rivets
Old 02-10-2019, 09:54 AM   #7
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
I just went through this, we repainted the fascia/bumper cover. Originally I was going to tape off the splitter.......but my paint guy really wanted me to remove everything for a better paint job. He was right. I thought I could get "good enough" hardware from Lowe's or Ace. I was not able to, so I went down the OEM route. They are not cheap!
All of the rivets went on with my rivet gun, it has several tips which came in handy since the plastic rivets are bigger.
92231490 Rivet, Front Bumper Fascia Molding, 10ea (plastic ones on the top of the facia, hold the 2 mounting strips on)
11546342 Rivet, Front Bumper Fascia, 8ea (these attach to the rear of the splitter)
11546343 Rivet, Front Bumper Fascia, 25ea (these attach to the front of the splitter)
Old 02-10-2019, 11:41 AM   #8
Turbo_J89
Thank you! Those part numbers aren't easy to find.
Old 02-10-2019, 09:27 PM   #9
h018871
Geoff
h018871's Avatar
A friend painted it, actually he was giving tutelage. He doesn’t do it as a job, it took us 2 1/2 weeks. Mostly because I’m slow, lol!
I wasn’t going to repaint it, he shamed me into it. It was very rough, but being a dark color the blemishes did not show up until you got close
Old 02-13-2019, 06:14 PM   #10
Turbo_J89
Well guys, I received the aftermarket metal and plastic rivets to remove and re-install the 1LE Splitter for $35 shipped. I plan to install 1 of each this weekend to test them out.
Old 02-15-2019, 04:33 PM   #11
h018871
Geoff
h018871's Avatar
Originally Posted by Turbo_J89 View Post
Well guys, I received the aftermarket metal and plastic rivets to remove and re-install the 1LE Splitter for $20.49 shipped. I plan to install 1 of each this weekend to test them out.
Where did you get them from and what part numbers did you order?
Old 02-15-2019, 09:32 PM   #12
Turbo_J89
I'll PM you.
Old 02-16-2019, 06:51 PM   #13
h018871
Geoff
h018871's Avatar
Greatly appreciate the effort you are putting into this Turbo. I sure want to save $$$ the next time I do this
Old 03-10-2019, 12:56 PM   #14
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
I am going through this too, bought a SS fascia, have to paint but I got so lucky with splitter found one for $30 on craigslist OMG. Mine didnt crack just got bent up so will try to repair it in case I crash again.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
