12-27-2017, 01:48 PM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
6th Generation Camaro CoverKing Silverguard Reflective Custom Car Cover
2016-2018 Camaro CoverKing Silverguard Reflective Custom Car Cover Save with code PHIL5 At Checkout
If you live in a desert area and your car sits outside you know how fast your paint and interior fades out and can start to crack. The Coverking Silverguard car cover has the highest UV rating available to keep your cars paint looking great and its interior fade free. This custom car cover will create a strong barrier against UV rays, water, dirt, dust, animal droppings, and other pollutants. All the fabrics used for this car cover are made from breathable materials to eliminate condensation under the cover. This Silverguard car cover is manufactured to the exact specifications of your 2016-2018 Camaro with mirror and antenna pockets included. This indoor/outdoor custom car cover will fit your Camaro like a glove and protect it from whatever life throws at it. https://www.rpidesigns.com/shop/item...tom-car-cover/ If you live in a desert climate, Coverking's Silverguard custom car cover is suitable for your needs. Not only will this cover provide maximum protection from the sun, but this unique 300 dernier, breathable polyester fabric will also protect your Camaro from rain, snow, dirt, and pollutants in the air. This custom-cover is manufactured specifically for your Camaro to ensure the best protection and fit possible. Made from a unique water-resistant, 300 dernier polyesters with special reflective properties to prevent sun damage to your Camaro Ideal for mild temperate climates (not intended for extreme weather) Strong heavy weave will not rip or tear Manufactured using double-needle overlapping seams and heavy wax-coated thread for durable and leak-resistant seams Highly breathable fabric prevents build-up of moisture under the cover Custom-fit design includes mirror and antenna pockets Special neoprene elastic tensioners in front and rear hold the cover firmly in place Covered grommets provided for optional cable and lock kit Available in reflective silver TRUE CUSTOM PATTERNS Like a fine suit, your cover is made to fit the curves and features of your vehicle. Our designers spent time with your model vehicle and used 3D scanners to record every compound, curve, and detail. That data is used to create a world-class cover with the fewest seams possible. Custom mirror and antenna pockets are sewn in to allow the cover to rest perfectly on your vehicle’s exterior. THE COVERKING ADVANTAGE Coverking designs its own fabrics and works with the world’s leading textile mills to handle manufacturing. With quality assurance teams dedicated to checking every batch of fabric, Coverking ensures that the material used in our products meet the most stringent assessments. We check to see if our material is breathable, allowing for the proper release of moisture. We exposed our fabrics to intense UV rays to make sure our fabrics do not fade over time. We go through a series of stress test to make sure the materials hold up for everyday conditions. Above all, our covers are checked before reaching our customer to ensure quality. |
10-31-2019, 01:55 PM | #2 |
12-30-2020, 09:17 AM | #3 |
Use coupon code RPISHELLEY5 for savings
Thread Tools | |
