Old 06-08-2017, 07:38 PM   #393
n813ca
Drives: 2106 SS
I live in FL and you can either cover the vent up or drive with your windshield wipers on all day. Lol
Sent from my SM-G935V using Tapatalk
n813ca is offline   Reply With Quote
Old 06-08-2017, 09:01 PM   #394
SPORTBIKES
SPORTBIKES's Avatar
Drives: 1967 Firemaro / 2017 2SS
Originally Posted by JLSuperfly View Post
Does this happen to anyone in California?
I'm in SoCal and my 2SS does it.
Mike Dee
SoCal USA
2017 Camaro 2SS
2015 Corvette Z06/Z07
1975 Supercharged Corvette
1967 Firemaro Show Car - For Sale
SPORTBIKES is offline   Reply With Quote
Old 06-10-2017, 01:27 PM   #395
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Umm..don't use the windshield vent!
CruzySS is offline   Reply With Quote
Old 06-10-2017, 01:37 PM   #396
n813ca
Drives: 2106 SS
It doesn't matter the air escapes around the door
Old 06-10-2017, 01:47 PM   #397
AdmAnt13
AdmAnt13's Avatar
Drives: '16 Red Hot 2SS M6 NPP
What an ignorant answer. That's not what the issue is.. it's not user error.
'16 2SS, M6, Borla Atak
AdmAnt13 is offline   Reply With Quote
Old 06-10-2017, 02:28 PM   #398
CruzySS
CruzySS's Avatar
I can replicate this problem only when the top vent is open otherwise I have no problem.
Old 06-10-2017, 03:48 PM   #399
Wheel Team 6
Wheel Team 6's Avatar
Fogging windshield
How do you keep the air from escaping the top vents? I can't run my ac in any mode without having cold air escape the top of the dash and excessively fogging up the windshield. I have to adjust the air temp to no lower than 78 degrees and fan speed on low or it hammers the windshield to a point the outside has condensation covering 2/3rds of the windshield. Then I run wipers and constantly hit front windshield defrost on/off raising temperature to hot to remove the fogging/condensation on the outside of the windshield. Then lower temperature so that I'm not sweating. Then the fogging comes right back.
Wheel Team 6 is offline   Reply With Quote
Old 06-10-2017, 04:26 PM   #400
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
That sucks! I only get a minor amount of condensation right above the vent with the a/c set to 72 when I first start up in the mornings. And I'm in 100% humid Houston... Once I'm outside my neighborhood and moving above 25mph, it disappears.
RCF is offline   Reply With Quote
Old 06-10-2017, 05:01 PM   #401
Wheel Team 6
Fogging windshield
Yeah this is the only complaint with my car fortunately. There isn't anything I have tried that works outside covering the dash vent completely while running the ac. Tampa Florida humidity is part of it I'm sure.
Old 06-10-2017, 07:19 PM   #402
n813ca
Drives: 2106 SS
If you read higher up they have come up with a fix. Unfortunately they have to rip your entire dash apart. I am thinking about it...
Old 06-10-2017, 07:52 PM   #403
Wheel Team 6
Fix
I am still waiting on my stealership to get back with me about it. I want it fixed as well.
Old 06-10-2017, 08:19 PM   #404
n813ca
Drives: 2106 SS
Stealership. I love it
Old 06-12-2017, 03:04 AM   #405
SuperSteveSS
SuperSteveSS's Avatar
Drives: 2017 ss
My 17 ss does this every day. I really don't want the dealer to work on my car simply because I don't trust them. Has anybody fixed this themselves?
SuperSteveSS is offline   Reply With Quote
Old 06-12-2017, 08:20 AM   #406
TedJS
Drives: 2016 Camaro SS
That is not accurate. The preliminary published procedure requires removal of the windshield so that a tool and small camera can be fished down the duct to aid the technician in finding and removing the foam block.
Dealers are strongly encouraged to reinstall the windshield after completing the procedure.
Dash removal is unlikely at this point as both doors have to be taken off in order to remove the dash as an assembly.
TedJS is offline   Reply With Quote
