07-09-2020, 11:33 PM | #1 |
Drives: 2019 1LE/ss 2014 ss/rs summit white Join Date: May 2016
Boost reading off from data log to analog
Has anyone experienced there boost reading not lining up from hp tuners to what there analog gauge reads.
My analog seems to be where I thought my boost should be at for my d1x. But every time i send a log to my tuner he tells me I have belt slip which I’m isn’t the case. 10-12 psi on the gauge and hp likes to maybe go up to 8 sometimes even lower. Ive done the man - baro and it still is off. Not sure if there’s a better way to read it. Thanks in advance.
2019 ss/1LE d1x, LT4 fuel System, Triple meth nozzle, ported BTR, 2” Texas speed headers, Built 377 SPDC motor, CTporting heads, TooHighPsi port system, SMG aux.
1014/800 on E55/meth 890/750 on 93/meth Working on tuning the port system for full e. With questions just message me here for a faster response. https://www.facebook.com/eric.willia...ibextid=LQQJ4d |
07-10-2020, 06:55 AM | #2 |
Mine logs in KPA and there is a formula for reading boost. So my kpa was ranged from about 225 kpa which was about 18 psi. Holley has a table for comparison. On my 5.99@119 pass I saw 237 kpa on the log which is 19-20 psi so it was making some hay on that pass but was also spinning the slicks some when it got out of the groove.
https://forums.holley.com/showthread...SI-Equivalents Should be read under intake manifold absolute
07-10-2020, 09:19 AM | #3 | |
07-10-2020, 12:03 PM | #4 |
Cool, hope it helps.
07-17-2020, 10:38 AM | #5 | |
Does your car have a Baro Break out harness and sensor or is your Baro disabled??
www.jannettyracing.com
07-20-2020, 03:05 AM | #6 | |
My analog will read 12 but my baro/Kpa are way lower. D1x with 4.25/8.25 pulley combo with rpm up to 7k
07-20-2020, 08:45 AM | #7 |
What Map sensor do you have and is it scaled properly in the tune?
07-20-2020, 09:09 AM | #8 |
It’s a 3 bar and you mean like na or tmap type of setting. I assume it’s scaled right but I have no idea how to see it. And my baro is the 1 bar(I have another 3 bar but was told it would be wrong to have that there)
07-20-2020, 09:15 AM | #9 |
Who tuned it?
07-20-2020, 09:19 AM | #10 |
07-20-2020, 09:49 AM | #11 |
Have you discussed this with him?
I trust the sensors more than the gauge as long at the sensors and calibration for the sensors are correct. Ted.
07-20-2020, 09:56 AM | #12 |
Yes he thinks my belts slipping but it’s not so idk what the heck’s up.
