05-25-2024, 06:06 PM | #1 |
Drives: Zl1 Camaro Join Date: Oct 2023
9.5 lower pulley
Is anyone running the iw lower pulley with a 9.5 ring from weapon x.
Thinking about doing this and keeping my upper pulley stock any thoughts or suggestions? |
05-25-2024, 08:24 PM | #2 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I am not, but I see no issues with that. Thats an 18.75% OD for the record.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC + RF BG Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + FIC 30 + DMS Front HX + Fender Tank GMS High Flow Impact Bar + GMS Stage II Oil Cooler + GMS Stage III HX System = 770rwhp 815rwtq @E55 13.5psi |
05-28-2024, 05:11 PM | #3 |
Does anyone know what the supercharger rpms will be or the amount of boost?
05-28-2024, 07:13 PM | #4 |
At 6,700 rpm, the factory blower spins at approx. 21,440 rpm.
with a 9.5" lower, that will increase approx. 18.75% or 25,460 rpm. Your results will vary based on elevation and other mods... but you should be in the 11-12psi range. What else do you have done to the car?
05-28-2024, 07:16 PM | #5 | |
I wouldn’t buy anything from Weapon X… terrible company with non existent support.
05-28-2024, 11:17 PM | #6 |
Will be doing a 103mm TB, 5” cold air, have kooks full 2” headers green cats and kooks mufflers then the lower pulley. Or would a smaller pulley be better?
05-29-2024, 06:51 AM | #7 |
Get the blower ported and add E before pulleys IMO.
05-29-2024, 07:45 AM | #8 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
You're going to turn the blower into a furnace real quick and then power will drop considerably as the ECU pulls timing to keep the engine safe.
You're better off with Flex Fuel and a 2.3 upper. You really need some blend of E when you put a pulley on these cars.
GM Gen V Calibrator
05-29-2024, 07:52 AM | #9 |
2016 NFG 1SS A8
