Old 05-05-2018, 04:44 PM   #15
Arugon
Arugon's Avatar
Drives: Summit White Camaro SS
Originally Posted by SinginHawk View Post
Hey Aru, thanks for the follow-up. Could you share some pictures of how the stanchions attach to the wing, from underneath?
Don't have any pics atm but I will see if I can get some up later today. They attach via 2 screws. 1 of which is a phillips screw that is not visible. The stanchion actually is hollow in the middle, there is a channel from the bottom part which sits on the trunk lid to the body of the wing where the screw goes through.
The second screw is a black allen head that is visible from the outside but doesn't stand out much. I do however HEAVILY recommend you temporarily mask off the hole for the allen head before putting it in as you can scratch a visible part of the stanchion when fastening the screw if you are not careful.
Arugon is offline   Reply With Quote
Old 05-06-2018, 05:38 AM   #16
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Looks awesome and thanks for the heads up on the install
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 05-08-2018, 07:05 PM   #17
ZYCLONE
Drives: 18 A10
wow thanks..................
ZYCLONE is offline   Reply With Quote
Old 05-09-2018, 10:56 PM   #18
SinginHawk
SinginHawk's Avatar
Drives: 2015 2LT
I know it's not a 6th Gen, but here's what it looks like on the 5th Gen.
I haven't attached it yet, as you can see there are some fitment issues that need to be sanded to the correct angles.
This wing is from 6LE Designs. The build quality of this wing is much better than the wing that Arugon received from 6LE.
I would still not recommend them, as it took 6 months and I had to call and arrange a pickup from the manufacturer myself after the 4th cancelled delivery date.
Size:  242.6 KBName:  IMG_1334.jpg
Size:  252.0 KBName:  IMG_1335.jpg
Size:  225.0 KBName:  IMG_1336.jpg
Size:  108.8 KBName:  IMG_1337.jpg
2015 2LT Cosmetics: ZL1/1LE Wing Spoiler, SS Carbon Hood, Z/28 Carbon Diffuser, SS Front Bumper, RS Taillights, 1LE Carbon Splitter, Phastek U-Halo Headlights, Fade-to-Black Gills
Performance: ZL1 NPP Exhaust, ZL1 6-Piston Brakes, ZL1 10-Spoke Wheels, Nitto NT555 G2 295/35/20 x 4, Magnaflow X-Pipe, Blackvue DR650S2-CH Dash Cam
SinginHawk is offline   Reply With Quote
Old 09-27-2018, 09:36 AM   #19
wlsmoku
Drives: 2018 ZL1 A10
old thread I know, but thank you very much for the write up and reviews from everyone. I will do the same when I get mine!
wlsmoku is offline   Reply With Quote
Old 11-28-2018, 12:51 AM   #20
SinginHawk
SinginHawk's Avatar
Drives: 2015 2LT
Awesome, keep us in the loop!
Old 03-11-2019, 11:43 AM   #21
james_s1296
james_s1296's Avatar
Drives: 2019 2SS (A10)
$800, C7 Carbon:
http://www.c7carbon.com/2016up-camar...on-fiber-p-671
- Their wing is identical to OEM specifications except for the stancions, which are their own design.
The stancions are similar to OEM, but the interior angles are less exaggerated.
This is fine for my applications since I plan to replace the stancions with shorter ones anyways.
They offer a non-carbon version for $100 less.
I went with C7 Carbon, due to their strong reputation, reasonable price,
and responsiveness to my calls and emails with questions.
@SinginHawk or has anyone else been able to find shorter stancions for the C7 Carbon 1le wing? I really want to find some that are a bit shorter so it doesn't stick up so tall. I already have the c7 carbon wing that is the short version not tall, but I want a bit shorter...
james_s1296 is offline   Reply With Quote
Old 08-27-2019, 05:06 PM   #22
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
Any new developments in the 1LE big wing world?
C7 Carbon still the way to go without spending "used car money" on the GM unit?
Thanks
Firecaptain is offline   Reply With Quote
Old 08-27-2019, 05:16 PM   #23
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
duraflex/carbon creations also has one now but i wouldnt buy one to try em out...
Old 08-28-2019, 08:10 AM   #24
Firecaptain
What is the "X" on the factory wing......manufacturer's mark?
Who makes the factory wing for GM?
Thanks
Old 08-28-2019, 11:47 AM   #25
PROMETHEUS
PROMETHEUS's Avatar
It is a separate sticker that is included with the wing! Don't know who the manufacturer is and I don't GM would tell you.
Old 08-28-2019, 12:20 PM   #26
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
C7 did my 5th gen:
Gen 6 CF on a 5th gen:
https://www.camaro5.com/forums/showp...postcount=2494
https://www.camaro5.com/forums/showp...postcount=2500
https://www.camaro5.com/forums/showp...postcount=2501
https://www.camaro5.com/forums/showp...postcount=2503
https://www.camaro5.com/forums/showp...postcount=2504
https://www.camaro5.com/forums/showp...postcount=2511
https://www.camaro5.com/forums/showp...postcount=2512
https://www.camaro5.com/forums/showp...postcount=2527
Just so you can see how they did it...
Very happy with mine...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 08-28-2019, 02:16 PM   #27
Firecaptain
That's what's on new ZL1 1LE's on the dealer's lot.....surprised GM would allow that.....
Old 08-29-2019, 04:21 PM   #28
SinginHawk
SinginHawk's Avatar
Drives: 2015 2LT
There hasn't been anything produced by a manufacturer except for C7, whose stancions are either at OEM height or slightly taller. I plan on going with a CAD designer on fiver.com, then a 3D printer, and finally a local shop to make a mold. It'll take some time to come to fruition, but I'll keep you in the loop. I'm going for OEM angles/fitment, so hopefully it will require no further modification.
Thanks
Yeah it looks like C7 is the current way to go. However, I'm personally not a fan of their straight-armed stancions or increased attack angle of the wing. I'm sure those design decisions have something to do with copyright at this point though.
