10-30-2020, 04:05 PM | #1 |
Drives: 2016 Hyper Blue Metallic 1SS Join Date: Aug 2020
Alignment TTY Bolts Part Number
Hey guys I’m reading that the 4 rear alignment bolts need to be replaced every time like this thread suggests:
Part Numbers: Front Shock Bolts: 11547494 Rear Camber Bolt: 11547215 Rear Toe Bolt: 11611276 However that OP’s car is SS 1LE, are the part numbers same for regular SS? I asked my part supplier and this is what they say: the part number (11547215) and (11611276) are only if you have the lowering suspension, in the picture I sent can you look to see what bolt numbers you are asking for? I found 22 part number (11611696) 28 part number is (11609598). This is the picture: |
