07-13-2019, 12:44 AM | #29 |
Drives: 17 camaro 2ss Join Date: Aug 2018
Hey curious on your outcome on that fuel pump. Mine just went out in need one asap. I am currently at 794hp to the wheels. F1A procharcher on 5.25 pulley. Meth injection. headers to full exhaust. cam, 3400 stall converter, .
07-13-2019, 12:48 PM | #30 |
Drives: SS 6 speed of course Join Date: Jan 2016
I tossed around LT4 LS + Voltage Booster
VS DSX second pump / Skidmarks second pump / Weapon X second pump VS Lingenfelter or maybe even a generic summit twin in-tank pump (summit is 1/4 the cost) I went with DSX, the driver is fully electronic and their quality is exceptional, customer support exceptional. I did not go with the voltage booster. IMO increase the voltage increases the stress of pump and frankly I'm paranoid of in-tank pumps (yes as part of my first degree I went to my junior year of EE). To my mind it is just SO much better to create a dual path system if their is a flow problem vs an increase pressure system (yes voltage is electrical potential aka pressure). I will admit since the Grand National days booster have shown to work and work well. Oh and the DSX pump is a million times easier to install vs LT4 + VoltageBooster if you start out with a LT1 as there is no drop the tank and fiddle with a million connections in the tank that only the wife's hands can fit. Also there is a serviceable filter and to replace or upgrade the pump is a matter of minutes. I ended up putting an indash light to let me know when the pump turns on. The twin tank is wow... but the $$$$ is way up there. The universal summit intake should fit IMO. I don't have a "spare" tank to try it on.
07-23-2019, 03:29 PM | #31 |
Dyno Show Queen LOL
just grab a DSX pump I'm holding at 75 psi at 865 on all e85.. If you need a high side let me know I have the LPE setup and 30 over injectors.. I want the 65% and the Kaytech beltdriven DI pump.
