Old 07-17-2023, 05:42 PM   #1
Bubbafire88
Bubbafire88's Avatar
Drives: 2010 Camaro ss A6 "Chief"
E-85 on stock fuel system
Hey y’all, just got my camaro back from the transmission shop after replacing the tcm, unfortunately they couldn’t program my current tune onto it so I’m forced to head over to my tuner to get a retune.
Got one heck of a deal on a dsx flex fuel kit and am wondering if I can just throw it on, get it tuned and have no problem, making 445whp currently with a tsp stage 2 cam, bolt ons, thru a 4400 circle d converter, built trans and 3.91 gears, not planning on doing any more mods for quite awhile
I know I won’t pick up much In terms of performance but I got such a good deal on this sensor and my tuner does the flex fuel tuned for pretty cheap
TSP stage 2 cam | aFe cai | Speed Engineering Long tube 1 7/8 catless headers | Self Ported TB | Circle d 245mm 4400 stall | ZL1 NPP Cat-back exhaust | 3.91 gears | Full BMR suspension/bushings |VMS drag pack 17x10, 17x4| Granatelli Motorsports pro stock spoiler| Heritage Grille | Zl1 Addons front bumper conversion kit | Whole lotta weight reduction
Bubbafire88 is offline   Reply With Quote
Old 07-17-2023, 05:56 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
Send it
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is online now   Reply With Quote
Old 07-17-2023, 08:32 PM   #3
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
I am making about 460rwhp but I am on a zl1 pump and 85lb injectors.
I would think you could do it with factory ss pump and injectors but the duty cycle would be A LOT higher. Tuner should be able to tell you.I picked up 3 rwftlbs and 9rwhp with my setup. Most of the gain seemed to be under the curve. Average hp and torque and throttle response seems more aggressive to me. Especially the hotter it is outside. Seems to work even better.
Gas mileage isn't that much worse imo than 93 and cost is a wash pretty much. I have a 3200 stall and 3.73s and my average gas mileage is not much worse if at all but I bet the stall and gear makes the gas mileage worse regardless.3.50 for premium and 2.74 for e85.
E85 smells way better! It is a stronger smell(like alcohol)but doesn't smell half as bad as 93, less smog smell but e85 is noxious. As soon as I pull in the garage I turn the car off and as soon as I turn it on I back out. Very strong while even garage door is open but sitting on the driveway it is way better. Wife loves it over 93.lol
ss camaro-monte is offline   Reply With Quote
Old 07-17-2023, 08:48 PM   #4
ss camaro-monte
As for fuel lines you should be fine. All the talk of e85 being harmful is overblown. Besides injectors and pump with the dsx fuel kit my fuel system and lines are stock. Now if you let your car sit a long time without starting then maybe e85 could be more corrosive but I only run 1/4-1/2 tank at a time and I drive my camaro at least once a week. If it sits a long time or I am gone for a few weeks fill it up with some 93 or mix the 2 but I know several on corn and they have never had a problem. Computer automatically recognizes the increased octane with corn and transitions between the two. In the cold e85 can be a little harder to start but in summer fires right up.
What is great about it is you now have 2 fuels that work with a high performance tune, smells better, slight power increase( 11.5-12.1 is where it would really start to shine, hence LT1gains.)
Only other thing I can say is that you should check your oil often regardless but e85 can dilute your engine oil some but I only put maybe 5k a year at most on my car. Oil is changed every 10-12 months regardless but at about 2k miles and 3 months it looks the same as 93.
Old 07-18-2023, 11:15 AM   #5
Bubbafire88
Perfect thank y’all, gonna send it and see what happens
My car is a daily, drive it a good bit every day. Cant wait to see what it picks up when I decide I’m bored with the car and mill the heads a crazy amount and go past 12:1 compression
Cant wait to smell that corn
Old 07-18-2023, 02:53 PM   #6
RupertPupkin
Boost it. Then you deff wont be bored.
730whp: 630Trq
Old 07-20-2023, 10:25 AM   #7
jeff657756
Drives: 2014 SS 1LE
You at least need injectors and likely at least a zl1 pump
jeff657756 is offline   Reply With Quote
Old 07-20-2023, 03:30 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I upgraded injectors. I was told I'd run out of injector going to E85.
CamaroDreams76 is offline   Reply With Quote
Old 08-08-2023, 01:17 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
boost + E85 = pedalfest...
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 08-08-2023, 11:25 AM   #10
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Just remember your taxing the fuel system 30% more
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
