03-14-2020, 04:29 PM | #1 |
Drives: 2014 Camaro SS Join Date: May 2017
What’s In My Oil
Hi Everyone,
Performed an oil change today (around 3k miles), and when pulling off my drain plug, these were attached to the magnetic end. Anyone know what’s going on? What these can be? |
03-14-2020, 04:32 PM | #2 |
Drives: cheby Camaro Join Date: Aug 2019
Stock rocker came apart. Pull valve cover look for needle bearings etc and replace broken rocker.. Drain oil and fish out all the needle bearing with a magnet. Its common on all the LS engines.
03-14-2020, 04:39 PM | #3 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Yep he nailed it. If I remember right, there are 22 needle bearings in each side of the rocker. Pull the valve covers and inspect. You'll have needle bearings everywhere. there is a service bulletin from GM about this. Basically says to clean out what you can and leave the rest since they wont go through the pickup screen. Now's a good time to replace the rocker trunions with aftermarket ones. Also, get a magnet and fish down in the lifter trays. I found several in mine. It's been 2 oil changes later and I still find them in the pan. I use a magnet to drag them to the opening and extract them
2014 2SS/RS LS3/M6
03-14-2020, 06:01 PM | #4 |
Thank you both for the help. Since this is all new to me, any thoughts on aftermarket parts I should order?
03-15-2020, 02:28 PM | #5 |
Drives: 2010 Camaro SS Join Date: Jul 2018
how many miles on engine?
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
03-15-2020, 03:04 PM | #6 |
I recently installed the CHE bushing set, which replaces the stock roller bearings with brass bushings for $200. Very easy install and I bought a Harbor Freight Arbor press for $60 that made pressing out the old bearings super easy.
The new bushings get held in place by snap rings and don't need to be pressed in.
03-15-2020, 03:39 PM | #7 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
How common is this and at what mileage?
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
03-15-2020, 04:20 PM | #8 |
Engine has 44k miles. So I took the valve covers off and looked at the rockers. None of them are broken. I should have taken a photo, but I wanted to see how bad it was. All rockers look good. A few were a little loose, nothing crazy. I took a screen photo of a rocker arm and pointed to where mine broke. Looks like it was the outer portion of the bearing/trunnion. I ordered a new set to replace the old ones and will do that this week.
03-15-2020, 05:10 PM | #9 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
03-15-2020, 05:44 PM | #10 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
On this day of national prayer and reflection, I’d find that shit in my oil truly horrifying! The stock motor has no better parts than this? In the Driveline world where I live, we consider needle bearings far superior to bushings. I’m torn on the idea.
For example, bushings have been tried and used in universal joints over time. Needles still rule.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
03-15-2020, 05:55 PM | #11 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Are you the original owner/buyer of this car? If not, maybe previous owner had an issue with valve train?
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
03-15-2020, 07:13 PM | #12 |
You know, I have absolutely no idea. Looks like I have some research to do tonight. I do know that they have oil channels in them though.
03-15-2020, 07:19 PM | #13 |
Drives: 2013 SS 1LE Join Date: Nov 2011
Thank you to all for the good info..very good thread
03-15-2020, 07:22 PM | #14 |
Gotcha me too! I’ve seen a few of these rocker bearing failure threads and it makes me want to Bush mine and not have to worry about it.
