02-28-2020, 11:54 PM | #1 |
Drives: 2017 TT ZL1 TH400 Join Date: Dec 2018
30% FIC or Katech injectors
It's a far reach but looking for a set of injectors +30%. Let me know if someone has some. Thanks
2017 TT Camaro ZL1 / TH400 / LME 416 / LME CID HEADS / Huron TT 68/71 106 / Crawford Port Injection / Holley EFI / AEROSPACE Components fronts and rears / 15" Weld Beadlocks / Torqbyte Methanol Kit / Prometh Trunk Tank / Plazmaman Intake
02-29-2020, 03:50 PM | #2 |
Drives: 2017 ZL1 Join Date: Mar 2014
This is 3rd party information: But I saw a Facebook post that Katech injectors did not perform as advertised. This person had much better success with FIC.
02-29-2020, 07:57 PM | #3 |
Thank you I have also just heard something in the same.
02-29-2020, 08:35 PM | #4 |
When you guys refer to the Katech ones, are those the new ones by XDI?
02-29-2020, 09:27 PM | #5 |
First I want to say I'm not saying I would not use Katech injectors. I am willing to try the 2 that are most present in the market. I have heard many things good and mediocre about many parts to find out I was pleasantly happy. So just want to clarify I would be happy with either brand. To answer the question yes the XDI is Katech. But just want to clarify I'm happy to purchase either. Sorry if the above post sounded like bashing it was not meant for that.
03-09-2020, 01:42 PM | #6 |
Dyno Show Queen LOL
nah Fic are just far easier to tune with unless you get the specs from katech or Uwe O. LPE are same boat..
http://www.xtreme-di.com/ I think Ryne Cunningham is in your state.. he might be a dealer for XDI and they will be less from him but, the fic should be even cheaper between 2200 and 2600 new. I hope ya do cam with the 44% lobe and LPE pump high flow hi side and what ever injectors you end up with. Also do not forget to get to get the LPE high flow ck valve setup.. all these parts will stretch the fuel system further til you get the the XDI pump or port injection level
