02-24-2020, 01:15 PM | #29 |
Drives: 2020 Camaro 2SS 1LE Join Date: Jan 2020
I haven't ordered anything big yet. Not gonna do anything major until after the break-in period anyway.
I don't have room in my garage, so I did buy a temp one and put that up so she has somewhere to sleep. I also got a couple of new tools and smaller items to work on her (I like doing my own work as much as I can). The only other things I was looking to get before hand was a catch-can, maybe some rock guards as I live off a dirt/gravel road, and probably oil for my first oil change. Part of my break-in process is an initial old change after the first 50 miles, or about a week. Especially with the way GM is testing these engines, I like to get that early oil change in to clear out any particulates from all the parts wearing together. After that, most of the break-in is for CPU and overall synchronization of motor, brakes, drivetrain, suspension, etc. After the 1500 break-in miles, I do another oil change and change diff fluid and maybe trans as well. I am planning on tracking my car occasionally and so I want to make sure it's in tip top shape. I totally feel your anticipation though. It's obviously eating at me too. Forgetting what weekend it was.
2020 2SS 1LE Riverside Blue w/PDR 1100 - 02/02/20 | 2000 - 02/10/20 3100 - 02/13/20 TPW 3/02/20 (Yeah right) 3300 - 02/14/20 | 3400 - 02/17/20 3800 - 03/10/20 ('Bout friggin time) 03/20/20 still just sitting there 9000 - 04/20/20 Covid sucks :( 5000 - 07/03/20 | 6000 - 07/05/20 |
02-24-2020, 02:25 PM | #30 | |
Drives: 2020 Camaro 2SS Coupe Join Date: Feb 2020
1100 - 1/30/20 | 2000 - 2/3/20
3000 - 2/04/20 TPW 3/02/20 3100 - 2/08/20 | 3300 - 2/13/20 3400 - 2/17/20 | 3800 - 3/2/20 4300 - 3/6/20 | 4200 - 3/9/20 5000 - 3/9/20 | 6000 - 3/10/20 |
02-24-2020, 02:39 PM | #31 | |
Well, I gotta wait for it to get shipped to me too. So probably gonna be even more of a wait for me.
02-26-2020, 06:30 AM | #32 |
We made it to Hump Day! Its all down hill from here!
02-26-2020, 11:09 AM | #33 |
Man, this wait is killing me. I just ordered a catch can for my girl. If I wasn't so busy with work right now I'd probably be banging my head against the wall. lol :eye bulge:: wave: (having a little fun with the smilies ... hehehe)
02-27-2020, 07:29 AM | #34 | |
https://my.chevrolet.com/content/dam...ers-manual.pdf
02-27-2020, 10:29 AM | #35 |
Yes, from everything I've researched, I wonder why it's not an option on every performance/tuner/high-end vehicle on the market. I understand that they are not entirely needed because the crap burns up in the engine, but that is just supposed to be fresh air. I don't want crap in my engine as much as I can help it and if a little part and 5min install will fix that, you know I'm gonna be all over it.
Thanks for the manual link. Didn't already have it, but now that I do, gonna have to read it.
02-27-2020, 11:57 AM | #36 | |
The most likely reason this isn't offered by manufacturers is that 1) it requires user performed maintenance, which cannot be expected of people anymore, plus an overflowing catch can cause severe damage, and 2) they think the rerouted blowby won't be enough to cause issues during the warranty period. Also, GM did implement a partial solution on the LT1.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 02-27-2020 at 06:03 PM. Reason: typos |
02-27-2020, 12:03 PM | #37 |
A catch-can definitely is not a "snake oil" solution. If it was, it would never need to be emptied. But yes, it's a part that requires some amount of maintenance. If your car runs out of oil or transfluid, it's also bad, and I'd be will to bet you could get any mechanic that does oil changes to also empty out the catch can while they are at it.
I am not familiar with the partial solution on the LT1, what is it?
02-27-2020, 06:02 PM | #38 | |
"Along with the improved oiling system, the Gen 5 engine also incorporates an all-new patent-pending integrated positive crankcase ventilation (PCV) system. This system works to reduce oil consumption (thus increasing oil life) by separating oil and air with up to 3-times the efficiency found in the Gen 3/4 engines. The new valve covers feature baffled domes between each coil to separate oil found in the crankcase from air, while the AFM solenoids feature revised "foul air separators" for similar reasons." https://www.gmpartsdirect.com/oem-pa...rator-12674766
02-28-2020, 07:03 AM | #39 | |
02-28-2020, 07:27 AM | #40 |
IT'S FRIDAY!!!!
02-28-2020, 09:15 AM | #41 | |
Jannetty Racing kindly added a drain valve to the bottom of my can that originally had to be taken apart, so I don't have to disassemble but just open and then close the valve to flush the can, but even without this, unscrewing the cap or the bottom of the can is a trivial task.
02-28-2020, 11:03 AM | #42 | |
From everything I have read and seen, if you are getting the 4oz model that is the most common vehicles (JLT, Mishimoto, etc. will all be referencing the 4oz units when you look it up be vehicle) after first installing it, you should at least check if not drain it every 1000 miles as the system gets used to the new part in line. After about 3000 miles, you should be OK to check it with oil changes, assuming you do those every 3000 miles. So example, either install it when you first get car or after an oil change. Check every 1000 miles until next oil change. Then just check with oil changes. (3000 miles) This is the most common maintenance I have seen for these devices and the least intrusive overall in my opinion.
