07-23-2019, 03:20 AM | #1 |
Small moisture circles on bottom of windshield when A/C on?
So I’ve been looking through the forums a lot, but most of the issues have been related to windshields fogging up, though mine’s didn’t seem to be excessive but, whenever I have the A/C on, usually on 77 or below, the bottom middle ONLY of my windshield (from the outside) get moisture circles, any fix?
This picture is the perfect example of my issue, it was the only one I found that matched my problem. BY THE WAY!! HELLO CAMARO FAMILY!! I’m new here!! Bought my 2SS A8 2 months ago!! Loving it very much, except for the throttle lag/response lol Last edited by 2SS6th; 07-23-2019 at 09:54 PM. Reason: Expect -> Except |
07-23-2019, 04:10 AM | #2 |
Change how you vent is blowing out, if that doesn't fix it some have made a mat to fit over the defrost vent in order to stop this from happening. Its annoying for sure but basically too much cold air is going through your defrost vent.
07-23-2019, 04:12 AM | #3 |
07-23-2019, 07:28 AM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Most cars do this. Turn on the defrosters with high heat and gone in seconds.
07-23-2019, 07:36 AM | #5 |
No new news here about the fogging issue! Congratulations on your Camaro and welcome to the forum!
07-23-2019, 07:54 AM | #6 |
Drives: 2017 Camaro RS Fiftieth Anniversary Join Date: Oct 2017
A known problem with the design of our car. In high humidity, condensation on the outside of the glass. Unfortunately switching the vent settings does not stop it as there is always some air directed to the windshield on every setting. I cover up most of the vents with a strip of rubber in July and August to prevent it. Not elegant, but its black and not very noticeable.
07-23-2019, 08:03 AM | #7 |
Drives: 2016 Camaro SS Join Date: Sep 2018
Most cars do not do this, this is a design flaw with this car with a piece of foam that wasn't inserted properly or is too big and it holds the defrost flaps open. The fix for it requires pulling the windshield and going in from the top to take it out. You can also like stated above cover the holes with mat material which is what I am doing.
07-23-2019, 11:39 AM | #8 |
Thank you Al Oppenheiser!
I use an oversize mouse pad. I don't daily my car, so it stays in the trunk until I find an occasion to use it (only 3 times since purchase).
https://www.amazon.com/Extra-large-G.../dp/B0713N6CFC[/QUOTE] |
07-23-2019, 01:26 PM | #9 | |
Drives: Camaro Join Date: Apr 2017
07-23-2019, 01:33 PM | #10 |
07-23-2019, 02:04 PM | #11 |
07-23-2019, 02:09 PM | #12 |
07-23-2019, 05:23 PM | #13 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
07-23-2019, 06:04 PM | #14 | |
Around here its 95F and 90+%RH every day in summer. The outside of your windshield will fog at a hvac setting of 75F if you’re not moving. Come on down and visit our home sweet swamp and see. |
