02-07-2024, 02:22 PM | #15 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
The 2" long tubes are not benefiting my build/mods (maybe hurting it?). When I decided to do my mods, I thought hey, bigger has to mean better and more power... nope ! My mods and lack of planning them out was my down fall. So I understand that unless I'm going for over 750 RWHP then 1-7/8" long tubes will work better than 2" long tubes. Also, my 2" long tubes seem to sounds more hollow and tin-can sounding than other ZL1's with 1 7/8" long tubes I've heard at my local cars and coffee. The 1 7/8" seems to have a deeper sound and I like that and prefer that over mine. So to help correct my problem, I ended up swamping out my $2800 Corsa XTreme axle back for a $2400 Stainless Works Legend's axle back. Again, lack of planning out what I wanted my end result to be. The Legends have much more of that classic muscle car sound I like. Adding to the above, if I did all this again today. I would port the supercharger and go wit ha NW 103mm throttle body. Andrew at CSP did my first set of remote tunes and he had me dialed in great. Then I wanted to go wit ha DSX Flex Fuel mod and CSP wasn't ok doing that remotely. So I ended up buying my DSK Flex Fuel kit& JMS Voltage Booster from JRE. Ted at JRE was invaluable to get my tune pretty darn perfect and running e60!
2023 ZL1 A10 - CSP 2" Long Tube Headers by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port/Polish w/Griptech 2.3" Upper | Granatelli Malevolent Coil Packs | Granatelli 0 Ohm Plug Wires | Katech Valve Covers w/Coil Relocation | FI Interchillers Blower Spacer Plates | Mighty Mouse Mild | JMS Flex Fuel Booster | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | AEM w/b AFR | Banks iDash Data Monster | HPTuners MPVi3 Module and Licenses (ECU & CCM) | Remote Tuned by Ted at JRE
02-07-2024, 03:09 PM | #16 |
Drives: 2018 ZL1 1LE Join Date: May 2022
Definitely. I don’t really have the cash to put down on porting the blower in the future; if I did that, it would be a while out. There’s no real benefit to porting just the snout and using a 103mm throttle body, right?
02-07-2024, 03:11 PM | #17 | |
I don’t really want to go too far with the car in terms of power; it’s mostly a street car and weekend track toy, not a drag car, and I worry about putting down 750+ WHP on a road course anyway. I think the furthest I would want to go with the car is a ported blower, but I don’t have the cash to do that right now anyway. |
02-07-2024, 07:08 PM | #18 |
Okay so after a little more research, I think I have devised a plan that will work well for me:
Have my shop install my headers and Big Gulp for now with the stock throttle body (I was not aware this was possible, but Rotofab sells an adapter for use with the stock 87mm throttle body). Have them install colder plugs while the headers are off. Have them tune the car with said mods. Then, in a year or so, when I have the cash, port the blower and install a NW103mm TB, and maybe some fueling mods to allow for ethanol (I still don’t think I want to pulley down for heat reasons as I do like to track it in the heat of Utah summers). This way, I feel like I’m not wasting time/money on anything; colder plugs will get installed while the headers are off, the intake is future-proofed, and I’m not wasting money on a throttle body that will bottleneck me when I want to port the blower (aside from the $20 adapter cost I need to eat). If anybody has any thoughts on this plan, I would love to hear them. |
02-07-2024, 07:18 PM | #19 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
02-08-2024, 07:21 AM | #20 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Nothing wrong with 1 7/8 inch headers on the ZL1 up until you start pushing 800rwhp. Then they actually start to show a bit of a restriction vs 2 inch. I prefer 1 7/8 headers on a street car because the low end torque at part throttle feels better without losing much, if any, up top to the 2 inch. Once you start adding pulleys and more airflow mods, the 2 inch headers start to shine above 6000 RPM.
Also, there is nothing wrong with porting the blower snout to accommodate a 103/107mm(Soler) TB. You will 100% pickup power by porting the snout and adding a 103/107 and Big Gulp. |
02-08-2024, 07:56 AM | #21 |
It's all about the best tradeoff for each use case, there is no "absolute best" part or setup that works best for every single scenario. As Ted Jannetty always says, we take a target and then use parts and a tune that "makes the engine happy".
