02-03-2024, 11:56 AM | #29 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
Same here. I'm hoping we will see the phase one (drop in pressure to 20 or so PSI) in enough time to take it in. I'm concerned about the ability of the repair shop whether that be Chevrolet or otherwise.
02-03-2024, 12:01 PM | #30 |
ZL1 Driver
That's awesome. You may have passed the point at which failure was indicative of a bad oil pump. There are people with 2017-18 that have original oil pumps with high mileage. I wish there was some way to tell who has those good and problematic ones.
02-04-2024, 08:39 AM | #31 | |
PKG4U
Either way as you’ve stated if we’ve made it this far on the pump our chances are good. I’ve also learned in this hobby and others like it, never hurts to have a plan b even c sometimes.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
02-04-2024, 10:24 AM | #32 |
Drives: 2022 ZL1 1LE Join Date: Sep 2015
Hi all,
The issues discussed here are the exact reason I sold my ‘18 ZLE. I loved the car but the low oil pressure was a constant worry. I never had it hit the 20’s, but it was always lower than I was comfortable with on a high performance motor, even switching to the 0-40W Mobil 1. My new ‘22 is consistently at 43-48 psi on cold start up and runs at 42-45 psi warm, cruising at 2200 rpm, using the recommended Mobil 1. These numbers are better than the ‘18 ever was. Whatever changes GM made to the factory oil pump it seems to be a reasonable improvement, based on my experience and the fewer post ‘20 MY numbers noted as failing on this forum. If I ever decide to add a bigger cam, I would certainly consider adding a Katech oil pump. I would have liked the dry sump oil system like my ‘15 Z/28 had too, but I guess that didn’t fit the Gen-6 platform. Good luck to all you early year owners, and to us all I suppose! JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
02-05-2024, 02:06 AM | #33 | |
Drives: 2018 Camaro ZL1 NFG metallic Join Date: Aug 2018
02-06-2024, 12:19 PM | #34 |
ZL1 Driver
02-06-2024, 01:59 PM | #35 | |
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
02-06-2024, 06:59 PM | #36 | |
Zach @ Katech said the repro required more and more stress with newer revisions, but eventually all GM pump revisions failed as they are essentially the same design with minor variations, whereas their pump is a ground-up solution. He is obviously a Katech employee, so there's that, but his info has always been trustworthy over time.
02-07-2024, 01:46 AM | #37 | |
Even in the AZ summer heat my ‘22 idles right at 39-40 psi. I can tolerate those numbers, which were much higher than my ‘18 was in the same conditions. I’m still using Mobile 1 recommended oil as l’ve seen no need to change brands. Again, I’m MUCH happier with the ‘22 ZLE over the ‘18. JJ
04-08-2024, 04:57 PM | #38 |
Drives: 2018 ZLE Join Date: Feb 2018
I have a 18 ZLE and have decided to also do the katech oil pump, timing chain and dampener katech recommend. I already have all the parts. My car was built 6/25/18 so it’s a later build and I have no pressure issues. Idles hot at 30 but with my warranty about to expire and seeing all these stories I figured why not. I even send my oil in for testing and the tests have always been great. My issue is what else to do while I’m in there. I’m somewhat limited on what I’m wanting to spend. We have some great shops here but I know this is a big job and parts are very expensive right now. Wondering what opinions are out there.
04-08-2024, 05:50 PM | #39 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
04-08-2024, 05:58 PM | #40 |
04-09-2024, 07:54 AM | #41 |
PKG4U
To my understanding a cam is a mod that has no additional requirements besides a tune.
04-09-2024, 05:49 PM | #42 |
ZL1 Driver
Called RPM shop about 75 miles away. It's $2800 for labor to change pump. I already have the pump. When warranty expires, I'll make a trip to them. Anyone work with them?
https://www.raceprovenmotorsports.com/ |
