02-25-2019, 01:26 PM | #99 | ||
Drives: 2018 Camaro ZL1 Join Date: Dec 2017
https://youtu.be/GVWqy2CaCPk https://youtu.be/BjIVZAP4a-E Last edited by RabbitZL1; 03-04-2019 at 09:50 AM. Reason: Gave credit to wrong member. Correct name is TMS |
02-28-2019, 11:02 PM | #100 |
So the results are in. 818hp 794Tq. Great powerband.
Im happy and not happy at the same time. Im not happy because of course i was expecting more. But I am happy that I completed this build on my own. All work and tuning done by me (except welding). After I sat and thought about it, the HP number doesnt really matter. When it 737hp last year, never thought it would go 140mph. So we will see how fast it goes. Just incase anyone wants to compare my old dyno sheet here it is: Track opens up next Saturday. If I have the time, I will go. Last edited by RabbitZL1; 03-01-2019 at 05:13 AM. |
03-01-2019, 06:03 AM | #101 |
I think those are pretty good numbers, I hope mine makes close to that tomorrow. I think you can go 9.50s@145. What drag radial are you running, 17" MT R?
03-01-2019, 06:26 AM | #102 |
Yup. I was thinking of going 15”. I’ll see how the 17s do. Looks like next week is no good for the track. :(
03-01-2019, 06:48 AM | #103 |
I was planning on the 15" conversion until I started having Tranny problems this week when data logging. It slipped so bad I got a notice from Onstar to take my car in to have it checked. It also showed up on my log. Its been an issue since I hurt the motor at the track last year, its slipped then and one other time last fall, received a notice each time then also. Trying to figure my next plan on that. I have to be in Commerce Ga. April 4th for the TVS Throwdown and its going to be close to get everything done so I can make it. I've yet to dyno and make a pass down the track with the new motor. Your car will be fine on the 17" R. I'm waiting for my predicted times so don't let me down. Haha.
03-01-2019, 08:39 AM | #104 | |
03-05-2019, 01:53 PM | #105 |
I don’t know if everyone knows but Fore Innovations just released a new solution for low side fueling. (Wish I saw this before I did the JMS). They have a dual and triple pump in tank setup. No more needing to drill a hole in the tank. I still may get it depending on how the JMS works out. Plan on running ignite red this year.
03-05-2019, 08:06 PM | #106 | |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
03-06-2019, 12:08 AM | #107 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
That power curve looks great. I think you did an excellent job. Congrats.
The true results will come at the track. I’m gonna bet you’re gonna be pleased. |
03-06-2019, 04:07 AM | #108 |
Yes. The car has 2 fuel pumps. Low side which is in the fuel tank like a regular car and a high side pump which is on the engine and driven by the camshaft. The low side pump feeds the high side pump. The high side loses pressure first with e85. You need an aftermarket cam with a bigger fuel pump lobe to increase the capacity of the high side fuel system. After that upgrade, the low side needs to be upgraded and the pump setup I mentioned can take care of that. Previously the only way to take care of the low side was to buy an auxiliary pump which requires you to drill and tap a hole in the fuel tank. Something I did not want to do.
I can’t wait. The new blower only record was set 2 days ago. 9.57 @ 143mph. My goal is to beat that! |
03-06-2019, 05:50 AM | #109 |
Good luck brother. I think it’s attainable
03-06-2019, 04:51 PM | #110 |
Just on the dyno Saturday, your a little higher then my 801 but my torque was right there with yours. My low side was dropping so we shut it off at the 801, wanted to add another degree of timing but decided to be happy with that, I may add another nozzle for a little more fueling. We shall see.
03-06-2019, 11:58 PM | #111 | |
03-07-2019, 10:10 AM | #112 |
1000cc AEM, but I ran 2 nozzles last year. I don't need it right now since its going to be so cool my first time out but will probably need it once I get to the Camaro Fest in July. I run a 50/50 mix, not straight meth.
