Old 10-03-2020, 11:12 AM   #211
gtfoxy
Drives: '21 Wild Cherry ZL1
Oh she’s gunna bark when those gates open!
Old 10-05-2020, 10:07 AM   #212
RabbitZL1
Drives: 2018 Camaro ZL1
Well we have lift off. Finished everything Saturday night and started street tuning Sunday afternoon. Had a few hiccups but got them ironed out. I added spark control, speed, and boost control to the Holley. Factory ecu is now only controlling the throttle body and direct injection. Everything works as it should. 3lb springs in the gates. Added 5lbs of dome pressure and it made 7.6lbs of boost. Can’t wait to hit the dyno and test the scramble button
RabbitZL1 is offline   Reply With Quote
Old 10-05-2020, 10:38 AM   #213
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
Looking forward to seeing results on this! Nice work!!
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 10-05-2020, 11:25 AM   #214
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Very clean looking! good luck with the results.
Old 10-05-2020, 12:37 PM   #215
RabbitZL1
Thanks. It’s been a long road with this install. I have to thanks a friend Clark Trost. He helped me a lot with tips for the install.
Old 10-05-2020, 05:25 PM   #216
gtfoxy
It’s going to be a beast!
I’d like to know more on the piggy back of the Holley system.
& Slightly off topic, but I have to know so spill the beans on the carbon steering add-one & the radiator cover.
Old 10-05-2020, 05:38 PM   #217
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
https://www.camaro6.com/forums/showthread.php?t=546716
Trufiber and octane motorsports for radiator cover
Many places sell the wheels like wildhammer. You can go directly to the source Shenzen Bo speed order how ever you want for about 100 to 200 bucks cheaper. You can use whatsapp to talk from 7pm to 5 am.
Old 10-16-2020, 12:03 PM   #218
RabbitZL1
So I went to the dyno last Saturday. Had issues with boost falling off after the gates opened. Was pretty frustrating. On the way home I realized I was really low on timing and that contributed to the problem as well as probably needing a loaded dyno. It made 914 at 6000 rpm on 15lbs. I know it would have made more of the boost wasn’t falling off. My plan was to stop at 20-21. After I added a few degrees the car really woke up on the street. So I’ve just been street tuning it for the past few days and it feels really good. Only downside is, it’s a dog off the line. DEFINITELY need a converter! Doesn’t make any boost until 4500 rpm in first and only gets to 7 lbs. I expected that so it’s not really an issue for me as I’ll be doing a converter and built transmission over the winter. I also remade the top section of charge pipe to make it a little more aesthetically pleasing. Overall I’m happy with everything and will be testing the car at a rental the 20th. Can’t forget to thank Joe Schneberger for some tuning help as well. I changed the tune to speed density and it drives better than it ever has! Pic of the bad dyno sheet and revised charge pipe below.
Old 10-16-2020, 10:12 PM   #219
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Very cool setup. Get it to the track.
Old 10-18-2020, 11:49 AM   #220
RabbitZL1
Going this Tuesday. Not expecting the best because of no converter.
Old 10-18-2020, 12:46 PM   #221
gtfoxy
Who do plan to go through for a converter?
Old 10-18-2020, 06:23 PM   #222
laynlo15
laynlo15's Avatar
That will be tough to launch a turbo car with no converter. Good luck
Old 10-19-2020, 08:08 AM   #223
RabbitZL1
suncoast
yea i just want to see what it will do. maybe go 160 lol
Old 11-19-2020, 10:53 AM   #224
Rabidsquirrel22
Rabidsquirrel22's Avatar
Drives: 2016 2SS
It's awesome to see the turbo kit get installed! Props to you for doing it all yourself. Looking forward to seeing how far you can push it.
Rabidsquirrel22 is offline   Reply With Quote
