Old 01-16-2022, 10:07 AM   #15
Dabjbr
Drives: 2020 SS 1LE
Never seen this before today…. Is this a ZL1 only part or anyone have it on a SS1LE?
I can’t say I’ve ever had a steering problem on track but I’m always a fan of improved cooling.
Dabjbr is offline   Reply With Quote
Old 01-16-2022, 12:30 PM   #16
Vigilante375
Drives: 2018 Camaro ZL1
It seems to only have been included with a 2019 ZL1 1LE and up. ZL1 non 1LEs do not have this extra airflow. So the SS 1LE doesn't this extra air flow.
Old 08-22-2023, 04:47 PM   #17
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
Does anyone know if these will fit on a SS 1LE? And will they be of any benefit on track?
Texan4iu is offline   Reply With Quote
Old 08-22-2023, 05:30 PM   #18
cdb95z28
cdb95z28's Avatar
Yes, they will fit. I have them on my '22 SS 1LE. I only installed them because I will be running ZLE sized 3Rs.
Old 08-22-2023, 08:38 PM   #19
Texan4iu
BLEW BIU
Texan4iu's Avatar
Thanks so much!
Old 08-23-2023, 08:09 AM   #20
Texan4iu
BLEW BIU
Texan4iu's Avatar
I had a weird issue this past Saturday on the track. I had a "Service Power Steering" on my dash and my car started violently shaking on only my 3rd lap of the day. The steering wheel was shimmying like crazy. I pulled into the paddock and even with the car turned off, the steering wheel and front wheels continued to shake. Finally after about a minute it all stopped. I hooked it up to HP Tuners and the codes I got were U0140 & U0422. I found another thread on here where a guy had the exact same issue, and he had his power steering assembly replaced. I'm in the process of getting that done, so I thought I'd add some extra cooling to hopefully help a bit.
Old 08-23-2023, 10:24 AM   #21
clg82
Drives: 2020 Camaro ZL1
subscribed for when i got an extra hundo lying around haha
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21
Old 08-24-2023, 01:15 PM   #22
waterman
waterman's Avatar
Drives: Grandad's C2 L89
I had the same issue a few years ago.
It required a CPAS reflash. After reflash, I've had no issues.
Service bulletin 19-NA-130. For your reference.
2018 ZL1 1LE sw/PDR
Old 08-24-2023, 01:30 PM   #23
Texan4iu
BLEW BIU
Texan4iu's Avatar
Thank you, waterman! I've read from others that sometimes the reflash helps, and sometimes it doesn't. I guess it depends on the cause of the problem. I've spoken to three different mechanics, two which are GM, and they all agree I need the entire assembly replaced.
