10-16-2022, 05:43 PM | #57 |
Drives: 2019 camaro ss Join Date: May 2022
01-12-2023, 02:45 PM | #58 |
Drives: 2017 Camaro 2SS Nightfall Gray 1LE Join Date: Mar 2017
My 2SS came with Spectrum lighting but not the footwell lights. It the install as hard if you're simply adding the footwell lights?
Specifically, do you need to have the BCM and HMI units flashed? Or is it closer to a plug and play addition? Thank you! |
01-12-2023, 04:09 PM | #59 | |
Do read post #44, though, working in the passenger footwell with your head practically stuck into a hole, then trying to replace the bottom panel with two bolts located waaay in the back is a massive PITA.
01-13-2023, 11:24 AM | #60 |
Sweet, I appreciate the quick response!
Agreed, the footwell is tiny. I had to remove the panel behind the glove box to access the HMI box to install my front facing camera. It comes with a reverse camera interrupt so when you toggle the camera on the video comes through the 8" built in touch screen. Just like the reverse camera. If I do this I would probably remove the passenger seat to have better access. Thank you! |
01-13-2023, 02:44 PM | #61 | |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
01-16-2023, 01:41 PM | #62 |
There is a long thread about different options others here have installed that I leveraged for my installation. If you still have questions send me a PM and I'll try to help.
https://www.camaro6.com/forums/showt...earview+camera Here is a DIY thread I referenced as well. https://www.camaro6.com/forums/showthread.php?t=498695 Last edited by NewCamaroOrder; 01-16-2023 at 01:57 PM. Reason: Additional DIY thread added |
01-19-2023, 10:04 AM | #63 | ||
D3RPZILLA
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
01-19-2023, 01:00 PM | #64 |
Thank you for the video willzilla! It was very informative.
01-20-2023, 11:56 AM | #65 |
D3RPZILLA
No problem, glad it helped!
02-02-2023, 10:17 AM | #66 |
Drives: 23 Camaro 2SS Join Date: Dec 2022
The video posted above is very helpful to successfully add footwell lights. Some of my thoughts are:
- Have a small ratchet with a 2in extension and 7mm socket for the multiuse module bracket. - Having the diagram of the multiuse module bracket is extremely helpful locating the rear 2 bolts. - You can use a wire coat hanger to feed the wire to the driver side no issues. Pay attention how you are running the wire, i had to do it twice (whoops) - First time using the Posi-taps that came with the kit. Watch an instructional video on youtube before it. Had to do this twice as the first time, i didn't tighten them correctly. Overall, i split this into two days, about an hour each day. This puts a hurting on the body... feet up over the head rests and head down into the footwell. Not a pleasant sight. Very doable mod for even the most novice mechanic, |
02-10-2024, 05:17 PM | #67 | |
Drives: Camaro 2016 RS Join Date: Jan 2022
For the records I have the IOB version (with the base 7" screen). WildHammer told me that I need to cut a hole in the left instrument trim panel. I read that you installed it as well in a 7" screen model, were you able to follow the GM instructions? Did you cut the hole? |
02-14-2024, 05:05 PM | #68 |
Trying to bump this as I still haven't installed the kit and didn't find anybody who did that on YouTube.
