Old 10-22-2015, 09:10 AM   #15
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
Originally Posted by Slickcas View Post
Funny you should say twin turbo. GM has a few LT TT's there testing. I hear one is a shorter stroke 6.2 at around 5.4L. Think of a 6.2 with a 4.8 forged crank shaft. The stock LT4 heads would flow very good is only pushing 5.4L. Should do very well against F@&$'s Eco-boost 5.0 that's in the works.
But we will be the stuck the crappy LT4 , I will be ordering a 17' with the A8 BTW!!!
I'm thinking a 5.5L V8 Twin Turbo at well over 700hp would be nice.
DrkPhx is offline   Reply With Quote
Old 10-22-2015, 11:49 AM   #16
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Any proof or links to said engines?
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 10-22-2015, 12:01 PM   #17
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
No do the calc, the 5.4 is 329CI i say it will be called a 327.
lots of rumor out there if you know where to go.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-22-2015, 02:08 PM   #18
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Over exaggerated as hell thing this has become... Zo6 engineer already explain it. Here is a link...
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 10-22-2015, 02:41 PM   #19
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
GM isn't going to put the LS9 in a new model. It will now live on as a crate motor. The issue with the LT4 isn't the motor itself, but rather the small supercharger which was selected because of the low roof line on the C7. The poor cooling on the ZO6 is due to the tight engine compartment and front end layout. The Camaro doesn't have those restrictions, so I'm pretty sure they will be a none issue. I'm also going to guess they put a larger SC on the Camaro Z car to bump hp but more importantly to allow the SC to run at a lower speed, thus reducing heat. A pure guess on my part.
I didn't say they were. I would be very surprised if they put a bigger blower on top of the LT4 that will be going into the ZL1 so therefore it probably will have the same issue as with the Z06 and CTS-V.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 10-23-2015, 03:51 PM   #20
Bhobbs
Bhobbs's Avatar
I don't get the desire to drop displacement. What would they gain by going from 6.2 to 5.5 or 5.4?
Old 10-23-2015, 10:24 PM   #21
TheSpectre
TheSpectre's Avatar
Drives: Boxster GTS
No.
That explanation (complete with long winded patronizing) was about the failure unique to the Z06 at Laguna Seca, which was not at all related to the repeated problems well documented for Z06 models on the track.
I want the alpha ZL1 to succeed, but I honestly would be happier if GM said "eff this" and stuck the LSA into the new car. Even it made no more power than in the Zeta ZL1, the 200 or so pounds lighter mass would make it amazing. I know that won't happen, so we can only hope GM tests the engine exhaustively in the Camaro, to ensure no repeat failure.
As it is, it's only a matter of time before C7 Z06 owners file a suit against GM, as the C6 Z06 owners have recently done. Only this one will be even bigger.
Fuel economy.
TheSpectre is offline   Reply With Quote
Old 10-24-2015, 05:27 PM   #22
Dutchman427
You and I are on the same lines of sticking with a proven engine. That is why I mentioned the LS9.
10.832 @ 130.99
Old 10-24-2015, 10:54 PM   #23
MrChrisLS3
Drives: 2018 1SS M6
Originally Posted by GretchenGotGrowl View Post
If you put any stock in what PeterMJ says about GM and the Vette then you are definitely drinking the Koolaid. He's got some beef with GM and put up is blogspot with the sole purpose to hurt them. As for the Yahoo review, well that's one instance and it is very short on details. Of the over 8K 2015 MY Z06s how many have had theirs go into limp mode?
PeterMj got his claim to fame from being ridiculous on the Corvette Forum in the C7 section prior to the release of the car. Basically still butt-hurt from being laughed off the Forum. Apparently same thing happened to him of the Viper forum as well. He's nothing more than an anti-social antagonist.
Is there a design issue with the LT4? Perhaps, it would make sense to me, in that superchargers in general are predisposed to a certain amount of heat soak, so a smaller one turning higher rpms would be even more so. I could see it as a possibility, but I'm also sure that the engineers that designed it are far more knowledgeable on the subject than I am. I do know that Juecter's comment on air trapped in the cooling system could be a cause. This is pretty common in any pressurized cooling system.
MrChrisLS3 is offline   Reply With Quote
