05-13-2011, 03:52 PM | #15 | |
- 2013 Black ZL1 - A6 - Lingenfelter/Cordes Stage 2.5 packages E85 - FORE Fuel System - Kooks LTHs - Magnaflow Cans - Rotofab CAI/Big Gulp/Coolant Tank - Savini 3pc Forged - Underhood Dress Up (ACC & Drake & Moroso) - Hurst Shifter Kit - Custom Audio w/ JL Audio Sub/Amp/Stealthbox - Hand Polished Brace - Oracle Ghost Sidemarkers - LEDs everywhere - 624/617 on E85 & 545/548 on 91 (Sept 2015) - 693rwhp (Dec 15)
05-13-2011, 06:24 PM | #16 |
Show & Go
Drives: '10 Camaro 1SS LS3 Join Date: Apr 2011
05-14-2011, 06:26 AM | #17 |
If you have someone lightly accelerate the motor while you are under the hood you should be able to see/hear if you have an exhaust leak. I would definitely check that since you did not use the supplied gaskets.
05-14-2011, 06:40 AM | #18 |
off subject kind of.... im gonna be installing bbk headers soon..should i use the gasket they give me or should i use the stock gasket? which ever one i use..do i just swap them out or do i have to put grease on them or anything?
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
05-14-2011, 06:42 AM | #19 |
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
Mine ticks, was sorta loud, added cam got a little louder! Asked the cam installer if that was normal he said yes! He stated the LS motors are also called "sewing machine motors" that is why they tick and they all do it to some degree!
Just the noise that comes along with the Headers. They are not as thick of metal as the stock ones!
05-14-2011, 07:07 AM | #20 |
Drives: LS3S/C Join Date: Aug 2008
When I had mine, l was paranoid thinking I had leaks and valve failure and when I step on it amplified the noise, at first when I got the headers it was not as laud but then, I began paying more attention and was thinking the worst, Aldo I hated the dam drone, but now I miss the loud tone, guess its hard to have both
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
05-14-2011, 07:40 AM | #21 |
Team Chevrolet
Drives: 2007 Z06 and 2011 Camaro 2SS Join Date: Jan 2011
Headers have a distinctive sound, kind've like a tik, but different. I had LT's on the goat and have 'em on the Z, both make the same sound, especially with a lumpy cam. A guy in an S2000 was chatting with me at a light while I was in the Z, but before the cam swap. He could tell that I had long tubes, just by hearing that "sound".
05-14-2011, 08:15 AM | #22 |
Hugger Orange
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80 Join Date: May 2010
Header noise
It is normal, every LS engine that I have listen to has had the old tick,tack,clack sound and the headers amplify the sound. I have an LS3 and I notice the noise more when the engine is hot and at idle also, cruising through town next to a high sidewalk will amplify the noise.
Hope this helps. |
05-14-2011, 09:30 AM | #23 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Yes, you will hear a lot more engine noise (especially in the 2k-3k rpm range) after getting long tubes.
Whatever noise your engine natually makes, the headers just magnify it. |
05-14-2011, 10:56 AM | #24 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
why do some peoples think you shouldn't use the factory header gasket
It is one of the best gasket you can use and always should use factory gm gasket. Isn't kooks gasket almost the same design as factory? |
05-14-2011, 11:02 AM | #25 | |
But this information is coming from a local performance shop. |
05-14-2011, 11:26 AM | #26 |
Drives: 5th Gen Join Date: Feb 2010
05-14-2011, 12:06 PM | #27 |
Drives: Camaro Join Date: Apr 2011
^ x2
A good friend will bail you out of jail. Your best friend will be sitting in jail beside you saying "That was F**king awesome!!"
04-23-2015, 08:01 AM | #28 |
Drives: 2010 Camaro SS/RS Join Date: Jan 2014
I installed LT headers and I also started hearing ticking sound under the hood. Seems like it's coming from the headers gaskets area on both sides. I also can hear it getting louder as I give it gas. Is this something to worry about or is it how the engine sounds with headers?
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
The BEST Break for a new car. "very long" | Darin Morgan | General Automotive + Other Cars Discussion | 346 | 02-04-2010 06:49 PM |
QC missed something-- AC Compressor making a whining noise under engine load | Kyle.Gilmour | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 10-09-2009 10:42 PM |
JBA releases exhausts, headers and midpipes. | Bewenched | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 09-16-2009 03:04 PM |
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 15 | 09-22-2008 04:35 PM |
