04-27-2011, 10:25 AM | #1 |
Break Necks, Cash Checks
Drives: 2010 black Camaro 2SS/RS Join Date: Apr 2010
Fuse pull AFTER tune?
Hey guys, this might be a silly question but I'm not sure. I have the SCT Jannetty tune on my car right now, 93 octane tune. Well I went on a road trip and the highest octane I could find when stopping for gas was 92. Could this cause the computer to go to a lower octane table? Could this cause issues with the engine since the tune is for 93? It's almost all gone one and I'm about to fill up with 93, so hopefully it'll be okay, just wanted to check with you guys!
Thanks -Adam
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
04-27-2011, 11:13 AM | #2 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
A fuse pull won't change the tune at all. And running 92 octane shouldn't cause it to switch to the low octane table.
04-27-2011, 11:31 AM | #3 |
Drives: IOM 2SS/RS Join Date: Jul 2009
I believe the high octane tables are copied over to the low octane tables anyway so in essence they are the same. Running 92 octane gas won't be a problem. I doubt that every time you fill up with 93 octane, you're actually getting 93. Depends how long the gas is sitting in their tanks. Make sure you go to a station that has high traffic flow, this should lower the chance of getting poor gas. I definately wouldn't put 87 or 89 octane in the tank, but you're fine with 92. The knock sensors will kick in and compensate.
ADM race intake, Dynatech lt headers w/hi-flo cats, Jannetty Racing dyno tune, VMax CNC ported TB, MGW short throw shifter, Elite Engineering catch can
04-27-2011, 12:23 PM | #4 | |
Although I would not recommend racing your car on Lower than 93 octane fuel Normal driving is Fine. A fuse pull does nothing with a tune. Ted.
www.jannettyracing.com
04-27-2011, 12:32 PM | #5 | |
04-27-2011, 01:19 PM | #6 | |
Thanks for the info!
04-27-2011, 02:27 PM | #7 |
Booooosted.
Never really got a tuners opinion on the fuse pull. Ted, is the LS3 and L99 the same as far as the fuses? Or does the LS3 need a battery cable disconnect too?
04-27-2011, 03:11 PM | #8 |
Fuse pull works on Stock cars.
04-27-2011, 03:13 PM | #9 |
Booooosted.
Cool. That's what I figured. I assumed most tuners take the low table off.
04-27-2011, 07:10 PM | #10 |
Drives: 1999 Trans Am Join Date: Jul 2009
04-28-2011, 07:18 AM | #11 |
ONLY if you modify and or disable the Knock strategy, too many tuners do this and it is dangerous..
And or if you Forcefully run it on 87 octane when it is tuned for 93. Ted.
04-28-2011, 07:32 AM | #12 |
Agreed.
That's a safety net. What about the accidental bad gas, or someone unknowingly putting 87 in. On some platforms, MAF sensor failure will default to the low octane table. There's a reason GM doesn't rely on the knock sensors only. If one runs good 93 all of the time, there is no reason to ever worry about the low octane table anyway. So making the low octance table the same as the high has what benefit under what circumstances? |
04-28-2011, 07:48 AM | #13 | |
04-28-2011, 09:58 AM | #14 | |
Booooosted.
My point was a good tuner will set it up so as to not need to pull the fuses. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
Fuse pull? | Rage | 5th Gen Camaro SS LS LT General Discussions | 22 | 06-06-2010 01:08 AM |
Something wierd after fuse pull | shroomjohn | 5th Gen Camaro SS LS LT General Discussions | 13 | 12-14-2009 11:02 PM |
FUSE PULL | CJ Offshoredude | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 11-26-2009 01:59 PM |
LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
