Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 01-06-2011, 10:15 PM   #1
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
Overhead rattle?
Anyone else's overhead console (where the sunroof buttons are) rattle? Mine rattles on the from left corner. Anyone got a fix for this? When I press up on it, it stops the rattle, but when I let go it rattles again.
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 01-06-2011, 10:16 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
I have a rattle too, but cant pin point it. It might be there
Click to view my build thread
The Stig is offline   Reply With Quote
Old 01-07-2011, 03:35 PM   #3
cybercamaro
Cybergrey
cybercamaro's Avatar
Drives: Cyber Grey
Send a message via Yahoo to cybercamaro
I have the same rattle. It drives me nuts. Would love to hear if anyone knew the cause
cybercamaro is offline   Reply With Quote
Old 08-07-2011, 10:25 PM   #4
Cody
Drives: 2010 Camaro 2LT
I have the exact same problem
Cody is offline   Reply With Quote
Old 08-08-2011, 08:30 AM   #5
Swytch
Swytch's Avatar
Drives: 10 2SS/RS Black, 99 Daktota
I just dealt with this over the weekend. It turns out (for me at least) the rattle was coming from the pieces that go into the overhead console for the dome light. The white box (part thats attached to the light switch), the silver bezel / reflector, and the clear plastic light cover. I took the box down (two clips towards the front of the car) and cut small pieces of dynamat and covered the inside and outside of the box the best i could. Its very slow going, you have to make sure not to cover any of the holes that the clips mount too. Once you get that done, it takes a bit of finesse with a small flat-head screwdriver (i call it a tweeker) to get it back together, as the dynamat makes the fit much tighter. My problem is all set, although i still get some rattle when the sunroof cover is pulled back. Looks like without that extra lateral support the whole housing moves.
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
Swytch is offline   Reply With Quote
Old 08-08-2011, 08:35 AM   #6
MEDISIN
MEDISIN's Avatar
Drives: 2011 CTS-V Sedan
I notice it when going over some pretty rough spots in the road. Couldn't tell if it was coming from the sunroof itself or the overhead console.
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft.
"Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree
MEDISIN is offline   Reply With Quote
2010 Boston acoustics back speakers rattle? "Bulletin: can't fix, normal" ?? tjk_art Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 67 01-12-2012 09:39 AM
M6 owners with gearbox rattle...READ THIS! KB2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 13 10-20-2010 03:02 PM
Body Rattle ? fargomike Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 05-23-2010 07:59 AM
Overhead rattle camaroMSUfan Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 03-30-2010 07:52 PM
engine rattle brainlady 5th Gen Camaro SS LS LT General Discussions 6 01-22-2010 02:46 PM
