Roto-Fab
Old 11-12-2023, 01:47 AM   #1
Camaro2ss6speed
Drives: Chevrolet Camaro 2ss
Need help
So today I drove my Camaro 2011 Camaro 2ss 6 speed and when engaging in reverse my lights don’t turn on but when I pop the trunk they turn on I’ve been researching and found bad reverse switch I have been looking where is this located at and cannot find an answer do I need to remove my center console?
Camaro2ss6speed is offline   Reply With Quote
Old 11-12-2023, 08:02 PM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
It is typically by your transmission so you may be able to access it from under your car.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 11-13-2023, 02:17 PM   #3
Camaro2ss6speed
thank you i will look for it
Old 12-12-2023, 05:54 PM   #4
Camaro2ss6speed
So I found it and I guess I ordered the wrong one also… is there a special tool to even take these out? My 22 wrench only loosens it up and I can’t turn it ��
Old 12-12-2023, 06:36 PM   #5
Camaro2ss6speed
Is this the switch? After disconnecting it and turning on my car I don’t get the reverse camera on my stereo after connecting it turns on so my question how can I remove this? I fit a 22 mm but it only moves a little after that wrench hits on the side
Old 12-14-2023, 10:17 PM   #6
Camaro2ss6speed
i figured it out.. the black plug with orange removes with a screwdriver and then you can remove the plug <3 geez.. couldn't find this anywhere
