04-19-2020, 10:35 PM | #1 |
Drives: 2015 ZL1 Join Date: May 2015
texas speed 2" headers?
anybody installed them in a ZL1? how do thay fit? any clearance problems??
4 innovations twin pump fuel system,DSX flex sender,28% lower,1 7/8 dynatech headers,id 1050s,rotofab intake
LS 2 ported throttle body,elite catch can,JRE rough idle cam,active innerchiller, tuned by JRE.... |
04-20-2020, 05:36 AM | #2 |
Drives: 2013 ZL1 Camaro Join Date: Feb 2018
Just yesterday I went back 20 pages in the engine/exhaust subforum for that reason. Lots of info going back to 2015. Didn't know long tubes eliminate stock cats. Killed my incentive. It would likely be too loud for me going catless.
04-20-2020, 07:18 AM | #3 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I've got a set sitting here in a box waiting for me to find a good weekend to put them on. I'll let you know.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
04-20-2020, 08:06 AM | #4 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
What do you need your stock cats for vs a High Flow Cat? Last edited by ZMEnow; 04-20-2020 at 08:24 AM. |
04-20-2020, 08:54 AM | #5 | |
From what I remember these fit pretty good on the 5gen. 2" will always give you some issues some where so just make sure you have good clearance before you bolt them up. From what I remember the steering shaft boot sits very close. Keep an eye for anywhere you're not getting about a 1/2" or more of clearance. If not, make a mark on the header, pull it out and dent it (we usually use a breaker bar and a mini sledge hammer to dent them). Last edited by Juiced1; 04-30-2020 at 08:43 AM. |
04-20-2020, 08:55 AM | #6 | |
You can always opt for the high flow cats from TSP and any other header MFG. Running headers with the factory cats would be a waste of a header. The factory cats are just as restrictive as the manifolds are. |
04-20-2020, 01:16 PM | #7 | ||
Drives: ZL1 Join Date: Dec 2016
04-20-2020, 07:21 PM | #8 |
good info.. thanx guys.....what i was thinking about doing is bumping up my volumetric efficency by adding 2" headers,
3" exhaust, RPM 5" intake , NW 102 throttle body i think it would be pretty easy to port the blower snout myself to make the 102 work... what do you guys think?? is it worth it?
04-20-2020, 07:59 PM | #9 |
Drives: T Join Date: Mar 2015
2" headers are great for power. Some 2" primaries ,if there are problems, are going to be near the steering column on the driver side. If it touches bonk it with a hammer a tad. 2" primary FTW!!
04-21-2020, 05:30 AM | #10 |
Primarily because of the pics you posted of melted hi flow cats. Have they been improved since then? I don't need more power, just love the sound and want a little more. Don't want to draw too much attention though. I would like the rough idle cam just for the pleasure of listening to it.
I was thinking ARH ceramic coated with stock catback, CAI, plugs, wires, 14/15 tray underneath. Then I have the original SC without a rattle (yet), so have some concern about warranty problems later. I could just do the solid isolator myself but don't really want to. Getting pretty lazy with age. |
04-21-2020, 08:03 AM | #11 |
Drives: ZL1 Join Date: Oct 2012
04-21-2020, 09:08 AM | #12 | |
04-22-2020, 05:21 AM | #13 |
04-29-2020, 01:36 AM | #14 |
Drives: 2013 ZL1 M6 Join Date: Jun 2017
Yes,
I had my shop install the 2" TSP Headers, Offroad Connection Pipes to 3" Corsa Sport Exhaust. While it is very loud, it is a race car, and I daily my civic, so when I'm operating my ZL1, I'm alive. If you want quieter, you can always do a LT header to Offroad connection and leave the NPP. Especially if you do a mild to wild switch, and cruise around with it closed, or if it's early in the morning or late at night for a car show. Perfect balance if you ask me. Do it!
2013 M6
Roto Fab CAI - TSP 2"/ Corsa, Pat G Stage 3 custom Cam Nick Williams 102MM, Griptech Pulley (2.45) DSX Aux Lower (9.45) - 1300cc FID Fuel Injectors McLeod RXT 1200 Trunk Tank w/ rule 3700 791/776 E85 YouTube: 3 Honks Away IG: 3 Honks Away |
