01-23-2023, 01:06 AM | #1 |
Drives: 2022 ZL1 M6 Join Date: Mar 2022
2022 ZL1 Baseline Dyno
Over the weekend I took the car over to establish a somewhat baseline dyno so that I'd have some data once I add more modifications. I know the number isn't as important since we are interested in delta, however the numbers seemed rather low. Could this be attributed to shit 91 octane? See details below:
Dyno was performed on a DynoJet, SAE corrected w/ smoothing: 5. 2 pulls. 63 deg. Fahrenheit, 30 deg. Fahrenheit dew point, 35% humidity, 30.28 inHg, -55.6' DA, 164' elevation. Vehicle info: ZL1 6 speed manual. 91 octane gasoline. Mods: NO TUNE, Rotofab intake (non-Big Gulp), Soler TB (91 mm, eff.), ADM Coolant reservoir v2.
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
01-23-2023, 01:24 AM | #2 |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
It really just depends on the dyno. I've seen anywhere from 520-580 in a stock car. I would just look at what is gained later with mods. 91 octane will pull more timing when heat soaked than 93 though.
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, and Elite E-2X catch can. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
01-23-2023, 02:18 AM | #3 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
01-23-2023, 03:49 AM | #4 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Hard to say without seeing logs however it would not surprise me if you're losing some on 91 octane since these cars are sensitive to octane even on 93, but I wouldn't worry about it if you're getting ready to mod it, the delta is more important as long as you're using the same dyno when comparing numbers.
01-23-2023, 05:50 AM | #5 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Really impossible to say. Some Dynos read generally higher in comparison to others across the board. What have other M6 ZL1s done on this dyno? Your numbers look like they fall within the standard range I’ve seen.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
01-23-2023, 07:46 AM | #6 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Based on the shape of the curve, I'd say you've got timing being pulled or throttle being closed. Likely timing being pulled.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
01-23-2023, 08:09 AM | #7 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
You are correct, a little low of other posted baselines... but i think it is inline if we agree on an 18% driveline loss. Like others have said... these cars done run their best on 91... and depending on your mileage, newer "tight" motors can dyno a little less. Like you said, just a number. As you continue to mod, I would try to use the same dyno, so you get the best back to back comparisons. Can i ask what shop you used?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
01-23-2023, 08:12 AM | #8 |
As others have already mentioned, you would likely see 15-20whp or so on good 93 vs 91. Even then 93 isn't really enough octane to keep these engines off the knock sensors. GM sets the timing maps up very aggressive and uses the knock sensors to keep the engine alive. In many cases I pull timing from the stock calibration so there is no KR even on a stock car with 93.
I have had some bolt-on cars that would only take 17 degrees on 93 pump gas without triggering the knock sensors. However, on E50 the engine would take 25 degrees all day. And this is why I am an advocate for running E85 or a blend of in these cars.
2016 NFG 1SS A8
01-23-2023, 08:38 AM | #9 | |
'20 ZL1 1LE A10,
01-23-2023, 08:41 AM | #10 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Ethanol is superior then race gas, not only for the octane but because of the cooling you get from ethanol. Is the 104 octane leaded? Everything in this area over 100 octane is all leaded.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
01-23-2023, 08:45 AM | #11 |
Silly goose, he can't see your posts. Probably best as he would argue with you that 104 race gas is superior to E85 anyway.
01-23-2023, 08:49 AM | #12 | |
Oh right, i keep trying to answer his questions but forget he blocked me. And yes your probably right....
01-23-2023, 09:12 AM | #13 | |
01-23-2023, 09:35 AM | #14 |
^^^, you'd have 20 rwhp more using 93, plus it seems you have some timing pulled in the midrange where your max torque is made at a little lower rpm than expected (it should peak at around 3750 rpm). I'd also join the E85 choir, it's an amazing value for a little bit of cost (flex fuel kit) and perhaps inconvenience.
