05-11-2020, 06:12 PM | #29 | |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
05-11-2020, 06:16 PM | #30 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Ah, yeah, that would have been me. I used to work right over there.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
05-11-2020, 06:39 PM | #31 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Very interesting… I just found some race fuel 100 Octane near me. I just need the car… lol
05-11-2020, 06:54 PM | #32 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
At high altitude it makes less difference, this is why you don't get 93 in NM and CO, maybe other states. CA is at a larger disadvantage vs the rest of the country, and it's a "special" CA only 91 that I've heard is even worse. Some cars like Subaru turbo cars have a lot of problems with it.
05-12-2020, 10:46 AM | #33 | |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
05-12-2020, 11:52 AM | #34 | |
Drives: Black Join Date: Jan 2017
My tuner tunes l86’s all over the country. (Blackbear if familiar) He was sitting in my passenger seat doing a street tune. Not many people In the world have more experience tuning l86’s while looking at live data. I’m quoting him “you’re not getting any knock, wow NJ has good gas” i was on 93. So if he’s surprised I’m getting zero knock on 93, you can bet your bottom dollar that all of you are pulling timing on 91. |
05-12-2020, 02:25 PM | #35 | |
This is common with the LS & LT motors. My C5 Z06's all did it too. Sucks that in order to get full performance, you have to basically pay double for gas. Mixing in 101 to get a mix of about 95-96 octane just about doubles your fill up cost.
Current:
05-12-2020, 08:38 PM | #36 |
Drives: '18 1SS 1LE Join Date: Sep 2017
I'm still waiting for California to declare gasoline a controlled substance. You know they don't want you burning that stuff.
'18 1SS 1LE Black, PDR
05-12-2020, 09:38 PM | #37 |
Drives: 1SS 1LE Join Date: Jul 2018
05-13-2020, 06:25 AM | #38 |
Yes he is right, at higher altitudes, which have lower barometric pressure, you don't need as high an octane as you would at sea level. You are more than 5000' ASL in ALB, so won't really need 93 in your stock 1LE up there, 91 should be ok.
05-13-2020, 11:38 AM | #39 |
Good to know! Thanks
05-14-2020, 02:46 AM | #40 |
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
A couple of gallons of E85 with every fill up will give you the same knock resistance and is probably cheaper than 101, and won't require a tune. FYI-adding a flex fuel sensor and tuning with E85 netted me 30 HP/30 FT-Lbs. of torque.
Bolt-ons.
05-14-2020, 03:52 AM | #41 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Agree with others, increased octane will not add power but it will prevent the loss from knock sensors to a point, going too high in a non-high compression engine will hurt performance. The larger concern is to make sure you don't use leaded fuel as it will poison your cats in short order, the Sunoco race gas sold here is 100 octane leaded.
05-14-2020, 06:33 AM | #42 |
I have seen Sunoco 100 at the pump and it was unleaded. Might want to check for more info on that pump that's near you?
