02-26-2024, 12:26 PM | #1 |
Drives: 2022 ZL1 1LE Join Date: Apr 2022
Brake Upgrades
As i get faster in my ZLE, I've been doing more reading on where to spend the money for upgrades. Im throwing everything at handling since this thing still has more HP than i know what to with.
I'm gonna do SS brake lines for sure (recommendations much appreciated). For pads and rotors so far im running all stock, and have only had to change pads. but i think my rotors are due soon, so im wondering if theres any pad and rotor combo that is worth the money. I know for example some ferodos have solid performance, and last twice as long, but also cost double OEM pads. |
02-26-2024, 01:02 PM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Brake Fluid, too?
02-26-2024, 01:36 PM | #3 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
You're gonna get lots of different opinions on pads. The OE rotors are the best cost per performance option there is. I like the Ferodo DS 1.11 but I street drive my car also. Some like the more aggressive Ferodo DS3.12 which would probably not be very street friendly.
Another worthy brake upgrade is the Caddy BlackWing front brake deflectors. I run the Spiegler lines with Endless 650 fluid. That car also has more handling than most drivers know what to do with! haha. Keep the suspension mods to a minimum. There's zero reason to swap out every suspension link/arm except the toe rod (SPL with lockout, no poly!). Tires, brakes, fluids, track time. Rinse and repeat!
02-26-2024, 04:52 PM | #4 | |
Factory rotor’s are stellar, it all comes down to compression, like lines, pads and fluid. |
03-01-2024, 02:18 PM | #5 | |
Looked at ferodo pads, and althigh they are supposed to have better bite, they're nearly triple in price. doubt ill get three times the life out of them. Maybe down the line i'll give them a try. (also of course i changed the fluid. Currently motul 660 but going to castrol srf moving forward, seems to be the the better choice). |
03-01-2024, 03:18 PM | #6 | |
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 03-01-2024 at 04:32 PM. |
