10-21-2021, 11:03 AM | #15 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
You could sell the other good tire if you do get a set of rear tires for replacement. What is the new tread depth for those tires? You can look it up on tirerack.com.
For reference, I sometimes get 1mm of wear difference side to side on the rears by the end of their life and it hasn't caused any issues with the eLSD or driveability on the street or at track days. |
10-21-2021, 11:09 AM | #16 |
True, I was assuming that it was deep enough to cause a leak if removed. If not, there should be no harm in continuing to use the tire after removal. I had this happen to me within the last month and almost all of the nail's shaft had been broken off before it got into my tire and I had no leak when the tire shop pulled it out, followed by no issues driving on that tire at a track day afterwards.
10-21-2021, 11:17 AM | #17 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
If in truth misery loves company here you go. I call this my $800 nail. 5 days before my very first HPDE day I ran over this. Had to purchase two brand new Toyo 888s for the Z06. Not happy but had no choice. I think you'd be OK to just buy one with 8/32 remaining but it still sucks!
10-21-2021, 11:23 AM | #18 |
Consensus is that you should be fine doing HPDE with a combination plug/patch professionally installed with the tire dismounted from the wheel and I have done it myself in my previous car reaching speeds of 125mph without any issues. The picture above shows a nail in the repairable area so "no choice" is not really accurate in that case. Some people do choose not to use repaired tires on the track for peace of mind.
10-21-2021, 12:04 PM | #19 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
10-21-2021, 12:46 PM | #20 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I had this exact thing happen to me shortly after I got the car.
Just replaced the one tire and the car ran fine. No issues with eLSD. Come to think of it, your left and right tires will wear a little unevenly by nature. That's why you need to do tire rotations. That nail looks a bit too close to the sidewall IMO, but you will have to get someone professional to take a look. If it is repairable, a full patch+plug job will ensure its integrity, assuming your tire is never very deflated before(as that will damage the sidewall). Right now I have a patched+plugged front tire on my car. Ran on the track without any issues.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
10-21-2021, 12:53 PM | #21 |
Tire rotations on a staggered 1LE...
10-21-2021, 01:13 PM | #22 |
I do side to side rotations at track days (mostly just front tires) halfway through the day if there is enough time between sessions, or between the first and second day if it is a 2 day event to prevent more wear on one side than the other but being able to rotate front to rear would be more beneficial.
10-21-2021, 03:47 PM | #23 | ||||
Drives: '18 SS 1LE Join Date: Jul 2016
I have hope that maybe this isn't too deep. I'm going to pull it out and have a plug ready. We'll see what happens. Thanks again |
10-21-2021, 06:00 PM | #24 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Take it to the tire shop and pull it out there yourself. I bet it’s not deep enough. If it leaks at least it’s leaking at the tire shop and not far away from the tire shop. If it leaks walk in and tell them you will likely need a tire. Better at the tire shop than at home or elsewhere.
10-21-2021, 07:07 PM | #25 | |
Just left and right rotation, as others have mentioned. Obviously, with a staggered setup there won't be any front and rear rotation.
Current:
10-21-2021, 08:16 PM | #26 |
376 cubic inches of fun
If the tire is not losing air pressure, you should pull the nail out ASAP, before it gets pushed in further.
If it continues to hold pressure, you're good. If not, the puncture is way to close to the edge for a repair. |
10-22-2021, 02:52 AM | #27 | |
Give speed a chance
10-22-2021, 11:26 AM | #28 |
Oh ok agreed in that case the tire definitely needed to be replaced due to sidewall damage from driving on it at such a low pressure.
