Old 07-21-2022, 02:43 AM   #1
Eric.18RS
Drives: Chevrolet Camaro
Second cat delete?
So i have catted downpipes with x pipe and mbrp quad axel back.The idle and sound of the car is perfect for me but I wanna go louder but I’m scared I’ll mess it up if i go with a second cat delete. Any opinions or someone that has this setup? I'm trynna see if someone has the same setup just with the second cat delete so i can see how it sounds when just driving by/ cruising / and full throttle.
Eric.18RS is offline   Reply With Quote
Old 06-14-2023, 02:01 PM   #2
Sortiez
Drives: Camaro LT 3.6L
i have my second cats deleted, no x pipe, flowmaster axle back. i do it for the free flowing aspect. i didnt notice much difference in the sound with the cats deleted. now if you did your primary and secondary then it would probably be much louder.
Sortiez is offline   Reply With Quote
Old 08-06-2023, 08:41 AM   #3
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
I'm going down the same route but with a cat back exhaust. Are the secondary cats just forstartup until the primary cats get to operating temp? Worried about failing the sniff test.
NiickySaz is offline   Reply With Quote
Old 08-07-2023, 12:15 AM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
if you want loud and no cheap sounding rasp, get a true x put in an mrt v2. Keep the cats.
also, hope you don't drive it on long treks and plan on adding dynomat even if you don't.
