View Poll Results: When should you replace track pads? | |||
2 mm | 3 | 50.00% | |
3 mm | 3 | 50.00% | |
4 mm | 0 | 0% | |
5 mm | 0 | 0% | |
Voters: 6. You may not vote on this poll |
Thread Tools |
04-07-2021, 03:15 PM | #1 |
Replace Track pads at X mm remaining
I have OEM Goodyear Supercar 3's on my SS 1LE.
I use Raybestos ST-43 pads for track days. Question: At what remaining pad material depth should i toss the track pads? 2mm / 3mm / 4mm pad material left? Thank you kindly, ~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
04-07-2021, 03:31 PM | #2 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
it really depends.....
- which pads? - will u have a back up? - are you beginner? - do you have the skills to change them at track? - are you able and willing to do inspections for material left properly yourself? i have gone as low as 2mm and then changed the pads myself @ track with new ones |
04-07-2021, 03:36 PM | #3 |
- which pads? Raybestos ST-43 pads
- will u have a back up? yes - are you beginner? not on my brakes - do you have the skills to change them at track? yes - are you able and willing to do inspections for material left properly yourself? Thank you for your ideas, seems monitoring is key. - i have gone as low as 2mm and then changed the pads myself @ track with new ones
04-07-2021, 03:54 PM | #4 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I'm sticking to a 3mm minimum for an all OE setup. I started a track day at about 2.5 once and during the first session I was overheating them to the point where the brakes faded severely enough to blow a corner, luckily no wall on the outside or anything. Swapped to new pads after that session and everything was back to normal. It somewhat depends on the track as well. If you've got the ability to monitor you could go as low as 2mm, but if it's an unfamiliar track and you know they're getting thin it's probably safer to at least move your braking zones a little earlier for corners without decent runoff.
2017 SS 1LE.
04-09-2021, 10:15 AM | #5 | |
Thank you for your insight, much appreciated apparently a POLL is too difficult for most people to figure out. I have 80 views and 3 votes
