04-05-2021, 02:19 PM | #1 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Splined strut bolt spun
Anything I need to worry about? My fault I didn’t know the damn things were splined and put a beefy impact on the bolt. Now instead of a interference fit it’s a zero tolerance fit lol.
I assume from what I can tell the splines are likely for easier install during manufacturing (and alignment) - and really do nothing to hold alignment (clamping of strut does that from what I’ve read). But just want to confirm that’s the truth. Worse come to worse I could flip the bolt around I suppose. Thoughts?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
04-05-2021, 03:08 PM | #2 | |
Pictures would help this a lot. Couldn't place your issue.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
04-05-2021, 03:47 PM | #3 |
Here’s a pic. Bolt is splined and interference fit into the steering knuckle.
It’s still tight (can’t spin it by hand) but you can spin it with a wrench. Basically my only concern is if the interference fit does anything to hold the alignment, if not and it’s all the clamping force then I have nothing to worry about. I just had to put a wrench on the bolt side to tighten vs just torquing the nut down.
04-05-2021, 03:51 PM | #4 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
Should be alright, as long as it's torqued to spec.
04-07-2021, 03:04 PM | #5 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Mine is the same way, alignment hasn't moved at all, i just make sure it's tight.
Thread Tools | |
