Old 04-06-2021, 01:02 PM   #15
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Originally Posted by Alpha1BC View Post
Depends on what level of driver you are. Running close to something a pro can run, have a lot of seat time, and are very consistent but somehow still using ABS/ESC instead of threshold braking yeah there's likely a measurable impact to lap times. If you're newer and still are learning how to handle the car at its limits then likely not.
It's kinda the same idea as switching tires or wheels to something not OE. Sure the control systems won't be 100% optimized, but it doesn't necessarily make the car undriveable.
do you think it'd be any less optimized than the Brembo 6 piston upgrade for the SS? which is like swapping over to SS 1le brakes?
joeyazzata29 is offline   Reply With Quote
Old 04-06-2021, 01:08 PM   #16
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have a 6 piston kit works just fine just make sure its all oem gm parts and you will be fine and no problems
Old 04-07-2021, 11:51 AM   #17
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Thanks man
Old 04-07-2021, 03:45 PM   #18
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
It'll be very slightly less optimized than the SS 1LE kit, but I highly doubt it'll be noticeable to 90% of people and probably would require a serious data acquisition system to measure the difference between those two kits. It's gonna be pretty insignificant no matter which 6-piston brake package you're talking about swapping to.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
