03-19-2021, 10:41 AM | #15 | ||
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Come on, everyone screws up from time to time. People make mistakes, especially if they are exploring the limits of their car. Quote:
It's like the Mark Reuss C7 ZR1 crash. One bad move and you have a bunch of strangers pointing fingers at you. I was amongst them until I actually tried to learn a bit about him and he is actually more than a guy that pushes paper like most people just assumed. He has a good amount of track experience, much more than most of the naysayers anyway. I think the damage shouldn't be that bad but it's a bit hard to tell the true speed the car crashed into the tire wall at as the wheels are locked up from braking.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
03-19-2021, 10:51 AM | #16 |
Drives: Camaro 1ss Join Date: Nov 2019
If you are pushing the limits and going for gold you are bound to crash in your lifetime. The people that never crash are the ones that don't care about their lap times.. Shit happens when pushing the limits. Kudos to this guy for being humble enough to post a crash video. Most people delete file and go cry with tail between their legs.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
03-19-2021, 11:12 AM | #17 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Thanks to the OP and follow up info regarding the nanny settings at the time.
I was reviewing the footage as well (I have some limited track time at VIR and tons of VIR laps on Forza) and wondering about nanny settings from the PDR video. Mostly so I could learn from this episode and hopefully avoid an off or crash at VIR myself. It looked to me like the car was in simple track mode (not PTM), and as there are no displays about "all nannies off" I assumed everything was turned on. Thus surprised the PDR showed no PTM or stability management engagement when the car started to rotate inappropriately on exit. But if the OP had turned the nannies off, then the lack of that intervention on the PDR display makes more sense. While not the best choice of settings or to use full throttle on corner exit before opening the wheel up (especially given the cold conditions at the time), that corner is one of the trickier ones at VIR. Carry too much speed in, and you'll go off on the right. Accelerate too aggressively during track out (or accelerate while rear wheels are on the outside gators) and the car will tend to over-rotate and hook inside. Combine that with the fact that you just went over a crest and are now heading down-hill, and it can be very difficult to catch the rear. On the simulator, I've put it into the wall just like the OP more times than I can count. |
03-19-2021, 11:41 AM | #18 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
So, I was actually there for that event. This was for the SCCA TT at VIR. There were two Camaros that wrecked during the Track Sprints.
You guys really need to chill out on the bench racing (sorry, have to be blunt here as I was there and I ran not too long after this gentleman). The other wreck occurred along the same element as this one and it was done by a very competent driver who knows VIR very well... The night before and that morning were a lot colder than the day before. The curbing at VIR is painted and is very slippery until the track gets warm. On top of that, the exit of T10 is a extremely common area to spin in exactly the way this gentleman did. The track isn't super wide after T10 and the road drops out of sight as you exit T10. The curbing extends just far enough and is very easy to exit that turn and over-shoot where the curbing ends The track sprint format forces you to go, essentially all-out right off the bat (it's basically taking a section of a track with an autocross mentality). What it seems to me is that the track was cold, the curbing was slick, the driver was running at a reasonable pace, took T10 as you would a normal track day, hit the exit curbing, perhaps caught some dirty/upset the rear over the slick curbing... slick grass... wall. The driver, in looking at the PDR, is in "TRACK" (all-OFF), and not in a PTM mode. Regardless, unless you are running a mode with stability control active, you aren't getting help from the car for this one. EDIT: FYI, the drivers are OK and the cars, both, are fixable. Both just have damage to the driver front. Looked mostly a bunch of plastic in the front, replace the crash beam and maybe a little pulling at the driver front, but not terrible. Last edited by Mountain; 03-19-2021 at 11:59 AM. |
03-19-2021, 02:11 PM | #19 | |
Drives: 2019 2SS 1LE Join Date: Mar 2020
The good thing as stated by others is that the drivers was unharmed and the damage wasn't major, so we can complain on the internet about someone screwing up rather than lamenting the death of the car/person.
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire" Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros) |
03-19-2021, 04:01 PM | #20 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
Words of wisdom. |
03-19-2021, 08:23 PM | #21 |
TWG1
Drives: 2019 Camaro ZLE Join Date: Nov 2019
Do you realize how amateur you look by calling this guy dumb when you’ve never even been on a racetrack? Quit the name calling and save the insults for a topic you actually know something about.
2019 ZLE M6
2019 ZL1 A10 (Sold) 1967 Jaguar XKE Series 1 Roadster 2021 F150 Powerboost (on order) |
03-20-2021, 05:01 PM | #22 |
Oh I know very damn well you don't apply full throttle during a corner in a RWD 400+ HP V8 car with cold track tires and nannies off, that is objectively a dumb mistake and it has happened to me but I managed to take control of the car so I guess I know what I'm talking about you get a C- for trying to dismiss my experiences too, try again later!
03-20-2021, 06:32 PM | #23 |
Drives: 1970 chevelle Join Date: Aug 2011
Tell that to someone that drifts with a car with more than 850 rwhp
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
03-20-2021, 06:34 PM | #24 |
love it
03-21-2021, 02:13 PM | #25 | |||
I have talked to a lot of experienced track people and yep, a few of them screwed up before and crashed their cars. Again, people make mistakes, and it's not really a good time to point fingers at them. There is a very real difference between split-second decision-making and hindsight. Everyone is a genius in hindsight. Quote:
Current:
03-21-2021, 10:22 PM | #26 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Where in Florida are you? In the Central Florida area (Orlando/Melbourne/Tampa) we have a very active AutoX group. There are 3-4 1LE's that come out regularly. It's a great way to start learning what the 1LE is capable of. And FYI - it's hardly $700 per track day. Track Night In America has events at PBIR every month. That's $150 for 3 20min sessions. PBIR is a great 'beginner' track. Forgiving and fun. We also have The FIRM, $225 for an Open Track Day...all you can eat from open to close.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-22-2021, 12:50 PM | #27 | |
03-22-2021, 01:05 PM | #28 | |
The FIRM has a coupon code for 1st timers...it's $50 off. Then if you register at least 24 hours in advance, you get an 'early bird' $25 off. If it is your 1st time EVER on track, then I think the require you to have an instructor in-car for part of the day. That has a cost, but I am not sure what it is. TNIA does not have that requirement. Track Insurance is a good idea. Check into RLI, not Haggerty. I have found RLI to be cheaper for almost every event...even the ones that Haggerty sponsors. For AutoX, it's the Central Florida SCCA Solo Group. https://autocross.cfrscca.org/ All of those events (and others) are listed on Motorsportreg.com https://www.motorsportreg.com/ You can search by distance and type of event and build yourself a custom calendar. You'll quickly discover you can do something with your car every weekend if FL if you have the time and $. You are right about FAST. Loren (FAST director) is just taking a hiatus AFAIK, due to his sites COVID restrictions. I would think he will be back when COVID is gone. There is also Martin Sports Car Club https://martinsportscarclub.org/ And Gulf Coast Autocrossers http://www.gulfcoastautocrossers.com/ See you out there! Matt
2017 HBM SS 1LE
