11-08-2020, 03:22 PM | #1 |
Drives: Tacoma 4x4 Join Date: Nov 2020
Residue on radiator cap 2014 Camaro SS
Hi guys,
First post here, didn’t find anything exactly like it. Went to look at a 2014 SS with the L99 yesterday. Garage kept, 25k miles, bill of sale from the local dealer and all except the last services done by the dealer as it’s now out of warranty. 16,500USD too much? Anyway, here is the real thing. I really liked everything about the car, driving it was awesome, but I can’t shake this picture off. Even though I really wanted to like it. This is the radiator cap. Ever seen anything like it? I should have touched it, but didn’t. Kinda does look like an oily residue to me, but even if it isn’t - nothing should be in an engine with this little miles, no? The owner claimed dust, but I doubt he had ever opened up the radiator. Could that be the famous oil cooler leak? Or even the block/head gasket? I’m getting back together with the owner on Monday at a garage of my choice. What test/diagnose will help solve this riddle? I didn’t see any oil leaks/stains, but haven’t had it on a lift yet neither. Is there a way to have a good look inside the coolant reservoir? I know this is little to go on, but I hope one of you has seen something like it. Cheers, Julian |
11-08-2020, 03:26 PM | #2 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
That’s from a lot of short drives where motor doesn't get up to temperature....had the same thing when I lived 2.5 miles from work (30-35 mph whole way too).....when I moved to 8 miles from work (and 30-50 mph) it doesn’t happen anymore.
11-08-2020, 03:33 PM | #3 | |
Edit: if I wipe it off and drive it around for 30 minutes... would it come back? Thanks again! Last edited by jgrueningphoto; 11-08-2020 at 04:25 PM. Reason: Afterthough |
11-08-2020, 03:52 PM | #4 |
Drives: ABM #93 Join Date: Oct 2018
Looks like orange dexcool residue to me. Kind of hard to tell from the picture.
Does the coolant overflow reservoir dipstick have oil on it?
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
11-08-2020, 04:07 PM | #5 | |
Idiot me didn’t think of the dipstick. Would oil stick to that? Would oil be mixed into the coolant turning it milky? |
11-08-2020, 05:12 PM | #6 |
Drives: 2015 Camaro Join Date: Aug 2018
Looks normal for a car with low miles that never had it's coolant changed. I'm sure there's nothing to worry about. Then again, I have even lower mileage with the original dexcool and my radiator cap looks pristine under it. So, maybe get the compression checked at the very least.
11-08-2020, 05:59 PM | #7 |
My gut feeling is your fine. If you’ve got chocolate milk in overflow than you’ve got problems.
11-08-2020, 06:01 PM | #8 | |
11-08-2020, 06:22 PM | #9 |
Jedi Master
I wiped it off, and it never came back...not sure what causes it, but haven’t seen it since I’ve been driving further to/from work
11-08-2020, 06:29 PM | #10 |
Drives: 2014 camaro 2ss/rs Join Date: Oct 2020
Dexcool residue. Have it changed.
11-08-2020, 06:33 PM | #11 |
Can also be residue from Water Wetter additive. Read it can leave sort of an oily residue floating on top when used...
Sent from my Pixel 2 XL using Tapatalk |
11-08-2020, 06:55 PM | #12 | |
Compression test is one option, but if oil is in the coolant, there must be a leak in the coolant system. External or internal, but there must be one, correct? So why not pressurize the coolant system with one of those pumps to the pressure otherwise held by the rad cap? If pressure is dropping, there’s a leak that lets in oil. If there isn’t... well, oil can’t go through where air can’t. Right? |
11-09-2020, 07:36 AM | #13 | |
Jedi Master
11-09-2020, 11:12 AM | #14 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I had crap that looked like that in the bottom of my overflow when I did my first cam swap. I was changing to ethyl glycol anyway, so I just cleaned the overflow. There was no oil in the radiator and the oil looked clean, so I just kept going. New cam and turbo later, still beating on it with no issues.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
Tags |
cap, cooler, oil, radiator, residue |
Thread Tools | |
